Woohoo 'bout time someone else joined Jeno, Jo and I at the hillclimb... next one is on the 25th May, having a break in June then having a 2 lapper in July.
C'mon Donnan, you should come to this one :)
I'm hoping Ben and Alex will be there too.
Should be out there, just my tyres are a little low after texi... So i will be a little lacking in teh grip department, But it will be my first time out there and my second event in the GTR so i will be taking it slow.
Unless i take the open wheeler :banana:
Bring 'em both :)
i bought 2 tyres today from north west tyres on wollongong street in fyshwick today, cheap as, they were only 205/55/16 though but still $80 a tyre fitted
You should have asked me... We have the 595EVO available in 205/55R16 - Awesome tyre...
Now you know :P
Congrats Michele on the win, not like they ever stood a chance.
Sorry we only got to see the last 3 laps. hope you enjoyed yourself.
Those last three were my best (which surprised me, they didn't feel like it) but I think I must have been showin' off cos you guys were watchin' me LOL
Oh bugger - it's now been edited :( - ignore above link, the content has changed and for some reason the button to EDIT is missing from my posts.
So here is what it said before the edit
Guys and Gals
I've just downloaded the data from Michele last run and yes - she was showin' off!!
She was carrying 200km/h through the kink on the straight and breaks down to 85 km/h in 5 seconds - gotta be happy with that!!!! :D
I think these smilies tell the story :O ...... :D .... :) ..... :)
We have analysed the data a bit more and an update:
Michele is pulling about 1.2 Gs (lat - thats pushing her sideways) through the corner. As Michele goes into the corner she is doing about 164 KM/h, so her braking from 200 KM/h down to the corner is in about in 41m in .8 of a second. As Michele hits the brake she is pulling about 1.2 Gs forward movement too. This is into corner two (one after the kink).
Few other stats:-
- corner onto the straight - pulling about 1.3 Gs side movement.
- fish hook - about 1.4Gs side movement
Edited by SteadyEddie
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
