hey guys i was wondering
i have a R32 Gtst...im about to do some mods... so far its 3inch exhaust,pod, fmic, power fc, front facing plenum, and heavy duty clutch and some extra boost.... im collecting the bits and pieces b4 i put it together.... i was wondering would i need a better fuel pump from standard?
if so do you have any recomendations of which i should go for?
Appreciate your help
https://www.sau.com.au/forums/topic/218287-fuel-pump-upgrade-necessary/
Its better to upgrade your fuel pump!! A lot of people said skyline stock fuel pump does not provide enough fuel!!! many of my friends get the nismo upgrade fuel pump. Also if you're going to upgrade turbo or anything else, you don't have to worry about your fuel pump again!!
You may not NEED the extra fuel at the moment, but you will need it to get more power with a decent tune...
The nice thing about a new fuel pump is thats it new... It gives you peace of mind knowing that it has a better chance of not dying, therefore killing your pride and joy...
Fuel pumps can die, slow lingering deaths, slowing reducing the amount of petrol to your engine and therefore possibly damanging it at the same time...
I have a walbro 500hp in tank pump. Not hard to fit, I use the standard pick up point and it doesnt make lots of noise... It didnt cost the earth either, coming in at i think 160 delivered... There are definately better pumps though, like the NISMO and TOMEI pumps, but they are circa $450+ delivered (are a direct fit though, with no mucking round)
All depends on what you are after...mods are never ending...trust us...we all know that far too well...
First step...change the fuel pump...as mentioned...a 18 year old pump is as good as dead and i can almost guarantee that it will be leaning out under heavy load...
had that problem on my r32.
stock fuel pump was causing my car to run lean, replaced it with a GTR fuel pump and all good now :banana:
If the GTR pump is 18 years old then it might soon start suffering from the same problem...even though its rated to flow more...with the price of warlbro and bosch pumps nowadays its probably better to go that path...
yeah thats true, with the prices of bosch pumps today, better to get that instead of gtr pump. Once the gtr pump starts playing up, then ill upgrade :D
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
