Oxygen Sensors Rb25 To 26
hey everyone im currently puttin a rb26 into a gtst and im using the 25 harness.... is basically the same except for knock sensor plugs.... in regard to using one single 02 sensor im unsure if i could use the rb25 sensor and it will compute properly with the 26 computer.... unsure if they are the same band width as such.
thye different i see is the plug and the wires are different coulours 25= white red black 26= white white black apart from that does neone know if it would work thnx
and yes im aware i will have to splice wires since im running single turbo setup..
different 02 sensors (type) and wiring
depending on what ECU you use, if you use an rb25 ECU, youll need to use a single rb25 02 sensor
or you can just leave it out and have no 02 feedback, the car should still work and run fine (just crap fuel economy)
Dont even bother.
Just turn them off via the Hand Controller, no need for them anyway.
I ran mine without for years, no problem.
I've only got a set in there now for the EPA so it doesnt flash a fault light via ECU codes/consult etc.
but just for shits and giggle i want the 02 sensor in there and functionable neways..... i have been doing sum reasearch and according to a couple of ppl the gtr sensor when the car is started the internal heater is on until car is hot then heater is turned off.... gtst sensor heater is constantly on also i have been told sum of the gtr sensor came with 4 wires not 3.... so yeh got me stumped for the minute lol
and as i said earlier i would just bridge the 2 inputs so i can get a reading for both and just even it out but yeh im aware thats its not needed for tuning with power fc.
the main thing i need to know is if i can or cant use the 25 sensor to a 26 computer thats my only issue
Edited by skylinekid
on closer inspection i have noticed that the 2 sensors for rb26 have to different plugs hence to not cofuse fron turbo with rear turbo sensors id say. the good thing is the 2nd sensor has the same connector as the rb25 so it will just be plug and play. but i will double check its functioning and not just hope it is lol. thnx for all the help guys much appreciated.
Still a bit confused by the problem, if you have 2 o2 sensors, why dont you just use them both, and wire it up the way it is from the factory
bcuz 1 sensor for one turbo ya dont need 2 plus i dont wanna have to run more wiring capeesch
 Share
    • The GTIII-SS turbos are not made for 650 hp crank. They just aren't going to do it. The turbine housing is smaller than the Garrett -7s. The turbo in general is smaller than a GT2860R-7, if it makes the same power as -7s you should be happy. Honestly I would be really happy with your results as far as power delivery goes. Hitting peak torque by 3500 rpm if that's actually happening in 4th gear in the real world is not normal for an RB26 at all. I have heard of people doing 2.8 strokers with GTIII-SS engines but I don't think I've ever seen a dyno sheet of it. I would be worried that the torque falls off faster than RPMs can rise so instead of getting a wider power peak you just shift the whole curve down 500-1000 RPM and end up with an engine that's no fun to rev out.
    • @Kinkstaah ....Shut up with all your good ideas, and common sense, but keep reading for a laugh  In other MX5 related news, work was quite so I went and looked at a few cars today, none passed the clean and un-abused, un-molested criteria that what I'm looking for, most were unloved junk really that kids had thrashed I did have a tip from one of the guys at work to look at a certain MX5, I actually forgot to ask about what model it was or the transmission, so after driving for another hour I arrived, got all excited about how the car looked from a distance as I was heading towards it, then when I actually got closer I found out it was a "NC" soft top, red, 99k Km, 6 speed manual, service history, garaged all its life, spotless, and most importantly 100% standard and a seller that was "motivated" to sell  The soft top roof line actually looks better than the hard top roofs that I have seen, so I decided while I'm there I might as well check it out, did some googling on common issues for a while and I spent about an hour looking for any issues, nope, not 1 issue, so I took it for a nice long test drive to see how it felt and fit Within a half hour of driving the car around Kinkstaar was proven right, and I wrong, I was judging the looks of a hard top car, but not the soft top version, and the NC is a much nicer place to sit than a NB, and the engine reved out really well The car drove beautifully, handled great and everything worked as intended so I thought I might as well see how much I could low ball the car, just for my fun, and the owners annoyance  I low balled, we negotiated, and yeap....... $14'000 later, ....I have new toy car, again Next step is I'll do all my usual "service everything" things for pure fun, and detail the thing the thing to within an inch of its life I swear, this car will stay standard, and I have no intention to modify it In other news, whilst googling about common faults and stuff, I found this interesting....and if you cannot see it, is it really a "modification" https://mx5mania.com.au/products/copy-of-ecutek-race-rom-tune-normally-aspirated-mx5-nc-2005-2013-2-0l-or-2-5l?_pos=2&_sid=1a693f332&_ss=r Cheers Kinkstaar
    • For street use I wouldn't bother with a clutch type LSD on the front especially on a mostly RWD car like the R32 GTR. It will affect steering feel and you're really not going to get much benefit out of it. If you insist on putting in a front LSD I would go with a Quaife or similar Torsen/helical LSD as that will have less impact on steering feel. R34 6 speed swap is not really worth it IMO. If you don't swap the final drive on the front and rear differential the car will rev much higher on the highway. For 120 kph it will sit at 3700 RPM, perceptually higher because the factory tachometer reads a little high. Stock transmission it's closer to 3050 RPM for 120 kph. If you change the final drive ratios you will have to either change the gear on the vehicle speed sensor or use some kind of converter because the gauge cluster is taking RPM of the transmission output shaft, not the differential output shafts. Add in the cost and the fact that it's not actually that much stronger than an FS5R30A especially in hard use due to the specification of ATF and I've given up on the idea of using a Getrag 233 in these cars. It's just not worth it considering the huge cost. If you want a stronger transmission build the FS5R30A. PAR Engineering supposedly will do whatever gear ratios you want. You can move things around so 1st and 2nd are not so clearly optimized for 0-100 kph acceleration. The gap between 2nd and 3rd is gigantic for autocross. OS Giken and a few other shops do this, take your pick.
    • What's your intended usage for the car? GT-Rs already have a mechanical LSD at the back, provided the clutch packs are still in good condition, it should delivery 50/50 torque split between LHS & RHS rear wheels.  Wouldn't hurt to put in a helical front diff, however would avoid a clutch pack front if you want to keep it streetable.
    • Hi all,   was wondering anyone upgrade these and what are their opinions? Worth the time to install for daily driver or just helpful for track cars. Or should just got with a full r34 transmission 6 speed swap. Are the lsd really neccessary with horse power over 600hp? Thanks
