im a casual but working more shifts than a full time
= awesome money, at least you can afford to buy a system LOL i have to stay with stock for a while bahaha go the DVD/TV duo with some good speakers, no need for subs or anything IMHO
just my2c
Andrew :(
Here is a different angle on why you could/should get a DVD deck over MP3 Deck.
My last GTR had a Haltech e11v2 which comes with software (to display in real time) gauges for engine vitals (i.e. boost, air/fuel, etc...) on a computer screen/PC setup.
I investigated further the concept and found out you can buy "car PC's, basically small boxes that house a computer with a A/V video out to your DVD Deck. You can also use a bluetooth keyboard/trackball mouse combo (cheap these days) all running of 12v....!!
These days you would just have a 8GB usb key as the storage device for the PC to load windows from.
This setup will negate the need of aftermarket gauges, you wont get pinged by the boys in blue for having gauges above your dash. Also you can have your screen open all the time displaying engine vitals with warning lights on the screen etc.....
I did not ending up doing it as buy that time I sold the car.
If anyone is wanting this type of setup, I will be happy to provide advice on setup, etc.....
Edited by im late
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
