Wrecking TWO R33 GTSt's, both series 1s, popular parts listed but all parts avaliable, for anything not listed PM me :)
Engine (RB25 turbo): $1800 each
Transmisson: $500 each
Custom Leather Interior: $800 for Front & Rear Seats
Series 1 Interior: $400 Front & Rear Seats
R33 GTR Wheels: $1500 set with brand new rubber
Aftermarket 5 Spoke Alloys: $700 set with tyres
R33 Type M Brakes: $400 set
G4 Coil Overs: $800 set
Door Shell: $200 each, no trim no window
Boot with Spoiler: $200 each
Tail Lights (pair): $150
Standard Rear Bar: $100 each
Dash Surround: $100 each
Leather Dash: $250 each
Cluster: $150 each
Lower Control Arms: $150 each
Upper Control Arms: $50 each
Quater Glass: $100 each
Factory Side Skirts: $250 set painted black
Factroy Rear Pods: $100 set painted black
Blitz Exhaust: $500, near new
Blitz Dump/Down Pipe: $150
Factory Car matts: $100
~Ferah
https://www.sau.com.au/forums/topic/218549-wrecking-two-r33-gtsts/
  • Replies 46
I have a mate who needs a shell. Is either one of them any good to use? Damage looks to be minimal.
Not concerned about vins or rego or compliance (racing)
Could you please PM me details.
Is the interior reel or fake leather???
Looks like the ones off the group buy and ebay...
Dnt no lol
yea both are fine if ur after shells, both have front on accidents u will need to repair tho.
Ferah,
Probably best thing to do is for me to come around your place and pick out the parts I need and we'll work out a price?
Can you please PM me your contact details and address and I'll drop by...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
