CRUISE - August 16th - Saturday - Brisbane - Gold Coast
  • Replies 80
Depends on which way you go.
I've organised a cruise for this weekend (with another group) and it goes up over mt tamborine from Yatala. Then through canungra, then advance town and then to Hinze Dam. On the way back we go through some REALLY windy roads (:( ) through to Oxenford.
If any of you are interested in attending this as a pre skyline cruise map out, PM me :) Slip, if you want the route, let me know. I'll gladly give it to you :(
I would just like to point out that on any skyline cruise I have organised or any I have been on, have had no police attention. Simply because we were being sensible and there was nothing they could do to us. Even when we had 35 skylines cruising down the highway.
What about that time Fully and Dave got booked, you were on that cruise :P
yer mick was pulled over, when sau cruised to gravatt once then onto goldcoast
apparently they had footage of 3 skylines racing on logan road...
then i was pulled over in southport after taking off at a set of lights next to paul.
i dont think i can make it, finding a driver for a night time is a bit harder than the day time deal
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
