Hey guys, little while ago there was a post where someone sourced some oil filter with the nut welded on top of the filter. Tried searching for it but couldn't find the post. Anyone know anything about them or been using it? Just curious cus i've runned out of oem oil filters and wanna to give them a go. Thinking would make it easier as i don't have a relocation kit.
https://www.sau.com.au/forums/topic/218678-oil-filter-with-nut-on-top/
autobarn sell a 'drift' branded oil filter with nut on it.. its blue! cost 20 odd busk though ouch :)
You're on to it mate, that's the one URAS is recommending,hey what's $20 bucks for the features this filter has especially the ease of getting it off.
I would still recommend screwing these filters on by hand as normal if you can,and only using the nut for removal as if you use a spanner to do them up they will get powerful tight,you know when you put on a fresh filter and tighten it up that you can back it off easily if you want to straight away, but try it in a week and you know how hard they get,just my 2c worth Cheers Grey Pearl.
If a filter is done up to the right torque settings, you shouldn't need tools to remove it.
Every single car I have purchased in the last 5 yrs has had some spanner in the workshop try to tighten the neck of the friggin filter, resulting in squashing and possible damage to the rubber seal, and making it damn near impossible to get the filter off after the heat has helped it to stick.
All cars (including my GTR) had a screwdriver help me to convince the filter to let go and give up, but after that, hand tight has been more than enough to make a strong seal with the filter and make it possible to get off by hand only.
B.
My hand and filter removal tool doesnt fit down there in a bnr32 :P
yeah exactly my problem
I believe this is the topic you are refering to
http://www.skylinesaustralia.com/forums/Sw...bl-t204892.html
That's the one, thanks for that cooper. Looks like it hasn't been updated. Has anyone been using these?
You do them up about hand tight, but dont use anything else to do them up. I have heard stories of engines who have been destroyed because the oil filter was over tightened, something broke off and blocked off the flow. Do it as tight as you can by hand, but you will need a tool to get it off. If it is loose, it will leak oil
LoL at some of the suggestions.
Filter removal tools are just that.. for removal; u never use a tool to tighten a filter.
Remove filter, clean o-ring seat, lubricate new filters o-ring, tight by hand with moderate amount of force - done.
there are some orange filters out there that have the end you grip designed with a grip like paint on them to help you remove them ;)
Your talking about the Fram Grip, I think.
In that famous oil filtration test done years ago, Fram didn't come up that well considering the cost.
Edited by GeeTR
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
