Time to get the daytime Stagea cruise going for next month.
Meet at a car park of which I'll disclose via PM on the Sunday 1st June at 9.00am. We roll at 9.30am on the dot.
Ensure you have fuel for the trip, or at least fuel to get to Victor (first stop).
Cruise will be heading south and then returning to Adelaide after lunch ... with some nice destinations in place to show off our Stags to the public.
A map/description of the exact route will be handed out on the Sunday morning.
This is a Stagea only cruise. By this I mean we have all Stags up the front for the cruise. Tag alongs at the back. If we got other cars mixing it in, then it just becomes an everyday car cruise. Our last night time cruise really turned heads with the number of Stags driving down Jetty Road, and we want to turn more heads again!
So who's in? :) Can I get numbers up for now and I'll PM you all the starting point in about a weeks time.
https://www.sau.com.au/forums/topic/218780-adelaide-stagea-cruise/
  • Replies 121
im in all going gd with my car and i can help with any organisiation. ruby can we say that the meeting place will be within 5 to 10 mins of the city? just narrows it down to get ppl keen but still leaving unanswed questions to unwanteds :) haha
Should've worded it a little different maybe - sounds like you're sending out PM's on 9am Sunday not meeting at 9am. :P
Whoops! ... my bad!
Is this better:
Meet at a car park (of which I'll disclose via PM before the day) on the Sunday 1st June at 9.00am. We roll at 9.30am on the dot.
ruby i have 2 more s2's coming out :)
Do we have names for these people/stags? :D
List revised:
RubyRS4
Tangles
dmonic1
chef_stagea
+ unnamed 1
+ unnamed 2
delichef
JayMei
webng
:O
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
