Item: R34 GT-T Stock Injectors
Age: Approx 80,000kms
Condition: Working when taken out
Price: $160 ono
To Fit: (What car) Unknown
Contact: 0411227356 or PM
Comments: Taken out of my R34 GT-T to fit aftermarket ones. Were working perfectly when removed. Top feed injector that may be an upgrade for some cars (not sure???). R32 & R33 are side feed for those of you who are interested.
https://www.sau.com.au/forums/topic/218825-r34-gt-t-injectors/
will get back to you soon if not sold.
ive got a non turbo....just need to confirm that ill need a safc2 to tune it with these injectors.
cheers.
Or e-manage...without it you'll puff big black smoke rings from running too much fuel
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
