don't listen to him..
yes you can replace with just one.
you'll need to make some sort of adapter up though.
I'll buy your shitty stock ones for $50.
that should be enough to have a custom, shiny metal adapter plate for your single atmo bov.
I would imagine just fitting one and blocking the other off as if you wanted to do the flutter it would work. I haven't actually seen the piping of the GTR and thought about it to really say.
Edit: Just realised there was no point to this post. :P
Edited by adam-__-
You can do that no worries, but remember its one pipe going into two bov's. Not two pipes, so all the air will just be fed to the one bov. You usually put two on as a better attempt to vent all the air. Putting one atmo bov on will just make it work harder and possibly not vent enough air so the excess would be sent back to the turbo charger and you would experience the flutter noise.
thanks for the info guys. I dont want to change the bovs by choice its just that i have bought a hard pipe kit for my gtr and the pipeing kit does not have provisions for the bov's to be plumbed back so my standard bov's are venting to the atmosphere at the moment and i think this is why i have poor idel and boost response takes a little longer to come on
Id say your problem is more likely attributed to the fact you're venting to atmo, not that your using stock BOV to do so.
IE stock or aftermarket, without a retune your still going to have the same problem
GTR stock BOV's are better in every way than almost every aftermarket BOV I have ever tried. It's a 99.9% guarantee that it won't matter what BOV you use, you will still have the same problem.
Cheers
Gary
if your car still uses AFM, then they have to be plumbed back in.
the factory ones do not stay shut at idle.
so essentially, you have an air leak.
un-metered air entering your engine.
a:f mixture is screwed and you get idle/stalling issues etc.
If you are still running air-flow meters, you need to plumb the BOVs back to make the car run properly. no ifs, no buts.
If you have MAP fuelling, feel free to go nuts with BOVs that vent to atmosphere.
there are people who have atmo venting bovs on AFM equipt GTR's with no problems.
but there is always some tuning to help it.
I'm not sure of the exact parameter that needs to be adjusted but it would have something to do with overrun fueling or throttle closed fueling or something that describes what the ecu does when throttle is shut.
basically, you want to remove fuel at that point so that when the atmo bov vents the air out of the system, then the ecu doesn't inject the fuel it was going to, that would have mixed with the air that was vented.
  • 4 weeks later...
My GTR came over with twin atmo Blitz BOVs, no major issues - just runs a lil rich between gear changes, but I would of kept the stockers if I had a chance.
btw the newer hks ssqv for gtr comes with the adapter/replacement pipe to suit single atmo bov.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
