  • Replies 71
Posted Images
aaah the turn 1 tyres strike again aye. lol
i swear dumbest move ever by mallala, so many cars are gonna get damaged. howd that orange 86 look after lol
but yeh i guess it will discourage ppl from dirt dropping
looking good simon, hopefully be up on the weekend to watch you. If you pick up a sponser you reckon you will keep the car?
Also, do all type have a trade plate? Keen to take the 31 down to them one day to have a look at my holey, slightly rusted rear 1/4 and see wat they can do.
depends on the level of sponsorship man. if its an all out sponsor then we'd prob import a fully set up track car from japan. burt if its a medium level i'll keep my car and develop it some more.
yeah all type have a trader, and a car trailer... call them and discuss your needs man
Wow that had to suck! Just like me getting a new turbo fitted to my car and three days later having some old bag run a red light in a Kingswood and write off my car! :wub:
And DON'T say "Not the Kingswood"!!!! ;)
pickle me grandmother!!!
thanks guys... thats 4th gear btw... its got decent power to smoke the bags at 4th at that kind of speed (150 ish kph)
mate, i would have trouble getting up the balls to enter those corners doing 100 ks in a strait line! let alone going 150, sideways!
its a real mans sport, thats why i dont do it lol, id rather go fast in a strait line ha ha.
haha yeah the weird thing is i feel safer drifting at high speed then i do sitting at 160 on the highway/drag strip thats sore sure... no idea how to explain that.
update on car: pretty much all finished! just gotta primer it for the weekend (wont be painted sadly)
So your car wont be at all type on saturday? Was hoping to have a look at it up close.
Try turn 4 at 230pkh on a race bike, knee on the deck, topping out 5th, and knowing if you lose it at that turn, you're going to hospital ... no doubts about that!
Then hard on the brakes to shave off more than double your speed for the northern hairpin.
:P
God, I miss my race bike :D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
