Just been doing some research, Seems the Kakimoto Regu 06&r is only 60mm in diameter at it's smallest point.. therefore it's only really a 2" exhaust.
Also the availability of the HKS Silent Power to suit a R32 GTS-T is pretty low. Might be able to get one from Nengun or somewhere, but i don't really feel like waiting till next year to install it.
The Kakimoto N1 is great, but it's a full system and i already have the split dump and high-flow cat..
Does anyone know of a reasonably quiet, quality 3" cat back system to fit an R32 GTS-T?
huh!? don't justjaps have any for r32's?
Just Jap has the HKS Silent Power for 32 GTR / GTS-4 , but not GTS-T.
The trust pe2 seems to be very popular for the sound, just not sure about the granny driving volume.. Seems the collective vote is for kakimoto or trust, with some votes for hks.
just incase no ones mentioned it.
hks = 3"
kaki = 3.5
stick with the 3.5 if ur aiming upwards of 300+kw
Sorry but thats incorrect!
The HKS is WELL over 3", Some of the mesurements I took of the outer diameter of the pipes were, 3.5" for the 1st part of the catback which is from the end of the cat to the square flange which the 2nd part of the exhaust containing the muffler bolts to, and the 2nd part of the exhaust measured 102mm (if i can remember correctly) which im pretty sure is 4" (correct me if im wrong please lol).
These would be more than up to the job if you were making over 300rwkw!
i will, just because the outa diametre of the pipe is 100mm or watver dosnt mean the exhaust flows that much. my cat has a 5" body but is a 3.5" cat.
but here are the official sizes for both kaki and hks newai....
HKS = Nissan ER34 RB25DET Tail 120mm, Pipe Size 85mm (2 Door)
KAKI = Nissan - Skyline ER34 - Pipe 90 - Tail 150
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
