Well Finally got Diked by the cops for my car. Recieved letter from EPA yesterday. Just wanted to know whats good Plumback BOV i can get?? as the Atmospheric one has to go. Im also Sourcing a Stock Airbox. oh yea.. Boost controler has to go and my PFC Ecu, but the cop rekons if i sweet talk the guys at the EPA i might be able to keep the PFC as its more efficient and makes the car run a bit Leaner? U guys think i can get away with it?
cheerio.
https://www.sau.com.au/forums/topic/219028-dam-epa/
Go the stock one, easiest way to solve your problem. Chuck in the stock boost solenoid, and remove PFC. There is NO WAY the boys at McLeod will let you keep it.
Also what exhaust do you have? Probably too loud, so chuck on the stock cat back or get a custom one made up that is under 90DB.
Good luck
https://www.sau.com.au/forums/topic/219028-dam-epa/#findComment-3863094
man this is a headache. I have a 4inch straight thru all the way from turbo. take it thats no good? in my opinion I dont think my car is not that loud at all, but spose i better get a stock one for the heck of it.
How the hell am i gonna find a stock ECU before my test date? their as rare as hens teeth these days.. can i get an extension?
O.k.. If say i do get these parts. i can fit the stock exhaust myself. put the stock airbox in myself, how much would i be lookin at to get a stock ECU put back in and i assume re-tuned. and removal of my boost controller? .
Also can I just get the PFC plugged back in and the boost controller, after the EPA fiasco is over and drive away?
It shit like this which disencourages me to keep my car. but i like it so much. Sad,
https://www.sau.com.au/forums/topic/219028-dam-epa/#findComment-3863943
4inch straight through, not a chance in hell.
As for the stock ECU, if you can find 1, plug it in yourself and drive away...the car will be back to stock power and feel like shit obviously, but it'll be fine...no need to 'retune' it as its stock and there's nothing to tune.
Once you plug the pfc back in, as long as the mods it was tuned with are back on the car it'll run like it used to.
https://www.sau.com.au/forums/topic/219028-dam-epa/#findComment-3863986
i highly doubt a 4" exhaust from turbo back will come near passing. when i went through an EPA test a year ago, i put a stock dump/front pipe and got a custom 2" rear muffler made with a peashooter tip from the last flange back. i just passed by 1dB.
no idea on what stock ECU's cost but i'm sure any performance place or jap wreckers can source one.
if your boost controller is a T-peice type, all you need is hose and 10 mins.
this is the world of jap cars where the law hates us. gotta live with it bud!
post your outcome and good luck,
dave.
Edited by dmr
https://www.sau.com.au/forums/topic/219028-dam-epa/#findComment-3864029
thanks for the Hot tips guys.. ill be callin every jap performance wrecker in town over the coming days.. as for avoiding it, I dont think you can mate, u may be able to delay it, like I have. but ultimately you will get done, I just left my house and went over the road the get fuel, and this patrol car started circling me like a shark ready to strike as i was at the bowzer, and thats where he got me. Even my mates stock as a rock r33 has been pulled over twice.
https://www.sau.com.au/forums/topic/219028-dam-epa/#findComment-3864353
hey i just got my EPA about 2motnsh ago! i had a pod filter, turbo back 3inch exhaust greddy catback with a greddy 3'inch dump pipe and a 3inch high flow... I took off my PE II Extreme and chucked on my OEM catback to the greddy trust dump pipe and JUst passed! 87.9 . So if i was u dude, chuck back on the catback!
https://www.sau.com.au/forums/topic/219028-dam-epa/#findComment-3864537
I took off my PE II Extreme and chucked on my OEM catback to the greddy trust dump pipe and Just passed! 87.9
Guys, that's not how the dB system works.
it's not a linear measure, an increase of 3dB represents a doubling of sound energy - eg 2x100dB cars doesn't equal 200dB, they'll make 103dB.
so geraus, 87.9 is a comfortable pass.
https://www.sau.com.au/forums/topic/219028-dam-epa/#findComment-3864678
Just use this change to get a proper quiet/flowing exhaust made
spending money on a "fix" IMO is dead money.
Sell the exhaust you have, put that (and the "fix" money) towards the new quiet one and never have a problem again.
No swapping etc. Time is money both literally and laterally in fuel cost and time off work, swapping etc.
Over the course of 2-3-4-5-6 EPA's you'll soon see that doing it when you should have was cheaper.
I used to do the whole swap the exhaust thing. End of the day its a pain in the arse after a while :P
https://www.sau.com.au/forums/topic/219028-dam-epa/#findComment-3868563
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
