  • Replies 89
so much hostility
but as for front bars! here's a few standard ones, nothing wrong with them but i really like the black one because the front grill changes the look a bit as well!
and then theres the 40th Anniversary factory optional front bar :)
Edited by typevu
well my kit is the GTR front which is fiberglass and fitts so well cant even tell, rear pods genuine so plastic, 400R sides genuine so plastic as well
thanx gtrkite i like mine to
and the 40th anniversary is the same as a M-Spec just has embrodary on the seats and a gay badge on the side near the window saying 40th anniversary soooo nothing special no more than mine
Oh it is that extra bit more... it is newer- late 1997 to early 1998 "40th Anniversary" were the last of the R33s, received additional factory option stuff, newer components, some "gay" badges to show off.... and etc....
It is somewhat like the '1997 Series 3 R33 GTR' to the '1995 Series 1 R33 GTR' or a '1994 R32 GTR V-Spec II' to '1993 R32 GTR' - between the newer/older there were additional factory options made available, some components were change, badges, price, resale value... some of the differences in those are more significant than the non-GTR R33 but so is the price difference.
Then theres something like the V-Spec II which is just BETTER because of it's sticker and is newer - sure theres the brakes and the wheels but because its a V-Spec II and is the last of it's kind it is something special over the others and will be a collector's item one day if it already isnt.
Edited by typevu
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
