  • Replies 547
Posted Images
Anyone after some 17" slicks going cheap?
Got one set of 24/69/17's for $240 (firm price) with heaps of tread left, they've come from a team who used them for one testing session. They're basically a 240/45/17 - i put one of them ontop of a 235/45/17 street tyre ive got and cant tell the difference except for the massive difference in grip between the two :)
Ive got 2 sets of them, and once my new brakes go on the car it needs 18"s so someone get a bargain
Got one set of 24/69/17's for $240 (firm price) with heaps of tread left, they've come from a team who used them for one testing session. They're basically a 240/45/17 - i put one of them ontop of a 235/45/17 street tyre ive got and cant tell the difference except for the massive difference in grip between the two :D
if only you'd posted that last week, just went and bought some semi's in that exact size :)
Sorry mate - how much were the semi's?
i got 205/45/17 on mine at the moment...
if i can confirm attendance on 21st ill definitely opt for a set.
Ok cool, let me know
take it your only selling the two? would be interested in all 4 at 120$ each.
when is the last day to be able to attend?
What do you mean?
Last day to pay???
Is it still in time for applying SAU member and CAMS license???
As soon as we see that you have applied for membership and the money has been transfered we can put you down as a member even though you haven't received your membership pack.
As for the cams.. You may be cutting it close. it usually takes 2 -3 weeks for cams to turn around your application but you can give them a shot..
You shouldn't need a CAMS licence for this event - a AASA licence can be obtained from Wakefield on the day (12 months around $50)
Also (correct me if I'm wrong SAU admins) but as SAU NSW is a CAMS affiliated club (not that you need CAMS for this day) you should be able to fill out the forms and pay SAU and get 12months CAMS on the day, keeping the 28 day stubb at the bottom of the form. The catch may be that there won't be any club admins there on the day who have the authority.
i've got another question, my power steering pump belt isn't in the best shape, is it likely to fail scruitenering or is it too hard to make that call with out seeing it? i'll try n change it before, but incase i dont get the chance
When it sells out you will have missed out but just before then is ok. The catch is that we don't know when it will sell out. Looks like coming down to the wire this time.
This is correct Michele.
$17 and 20 minutes. Even if you buy it and then fit it on the morning at the track it's worth it.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
