  • Replies 87
Is anyone going to come up with an actual model or part no??
I have a friend who owns a specialist 4x4 workshop and he carries at least half a dozen different clutches for the various year and models of the Patrol, and, they are not interchangeable.
  • 2 months later...
  • 2 months later...
the power limit would be like the amount of torque a patrol can throw out, plus its in a 2 ton vehicle. But I still wouldn't take it past the other daiken exedy H/D limits which are rated @ 450hp - I reckon they are a bit overrated powerwise.
Sumo
Well how come the part number for the Daiken HD for a Skyline is R5208HD...
I have spoken to both Daiken distributors and to Coventry Auto, and have recieved the following information.
"The Nissan Patrol Clutch kit will fit, it has a higher rated pressure plate than the standard Skyline pressure plate. Noting this the pressure plate is rated so as to match the torque characteristics of the Patrol engine, despite sharing similar flywheels, clutches are designed with different applications in mind."
and this
"The Skyline HD clutch has an uprated clutch plate compared to the Patrol Clutch plate. The clamping pressure is similar however the the combination of varying clutch and pressure plates are designed to take either big torque low rpm, big torque high rpm or any combination in between."
or
"We do not recommend the fitment of a Patrol Clutch to a skyline and vice cersa, they are designed for different purposes and the clutch compound is different for both kits"
Don't kill the messanger, this is the info I recieved.
just thought i'd chuck in my 2 cents, even though the two clutches would be made of different compounds the low down grip and clamp that the patrol harnesses for distribution thru 4 wheels SHOULD be a godsend for hard as fu** launches, i suspect what daiken have in mind when doing their extremely expensive r&d is how fast is the clutch going to spin with what amount of torque thru the rev range and what sort of pressure can be applied to said clutch at different points. BUT i still reckon that it is worth a try, i mean what is 5-600 bucks in the scheme of things if you are going to find cool shit that that can be cross fitted, my clutch is starting to slip too and the patrol clutch is going straight in, why not. least i know it wont fall apart on me when racing me some commode-whores! Peace.
even though the two clutches would be made of different compounds the low down grip and clamp that the patrol harnesses for distribution thru 4 wheels SHOULD be a godsend for hard as fu** launches.
You really think that Daikin chose a clutch plate material for Patrols that will withstand hard launches? How many people do you see doing high rpm launches in their Patrols?
Just because it fits, doesn't necessarily mean that it's suited to the application, is what Daikin is trying to say.
I wouldn't know what to think. There are several people here with Patrol clutches now. To you guys - How many hard launches has the clutch withstood so far?
what i was saying that is with a 2+ ton vehicle running a 4wd drivetrain, made to take the extreme pressure that mud, sand offroad etc would put on the clutch and p/plate that hard launches should be a sinch, i realise that the rpm is different with launching a line and a patrol, but it is made for a pretty heavy duty application.
this has all been extremely interesting, i feel so conflicted. i will now consider a patrol clutch. one thing no one mentioned is the torque that a 4WD has. id have to agree that if a patrol clutch can take the low end toque, it should handle high rpm dumpage from a relativly light car, for a little bit anyway.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
