hey guys need some help with some wiring
most of it plugs in by the looks of it but need to be sure with everything
one main one is the RB26 resistor pack.
I got the resistor pack for the 26 but i have looked around the wiring loom and there is no plug that goes straight into it (is this right?)
so just asking where abouts do i wire it from
and also how does the rest of the wiring go
thanks
Gordon
https://www.sau.com.au/forums/topic/219675-help-with-wiring/
The 6 power for the injector wires go to a plug that ends at lhs front area of the loom, sort of near the afms. You need to wire up 1 power feed to the resistor pack, then 6 wires out to the corresponding wires at that plug. If you have a multimeter with a continuity tester you should be able to find the wires, one at time by disconnecting the injector plug and or matching the colours up by pulling back the injector plug boot. If my gtr/sil80 was at home id tell you the colours. Hope this helps.
resistor pack wont simply plug in on a gtst as its part of the loom that is where the fuse box is
you'll need to hardwire the resistor pack into the engine loom.
do a search theres a tutorial on how to do it on a gtst for installing gtr injectors, its the same as fitting it to the 26 in your case
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
