  • Replies 504
Originally posted by GTS-t VSPEC
Erik, Read my new sticker thread, and no nothing in life is free:p
STICKERS!!!!!!!
Did some say something about STICKERS. Arrrgh yes more RICE hehehehe.
Car gets DE-RICED soon :) not for long, new ones here next week :)
thats not too bad ..... half price i guess :)
I would check with Danny he got my shirt too .... probably did but just n case you dont want to get them all back and be missing one .... too late by then
Hi Paul and eveyone,
Right, I did some checking with regards to floor coverings and the price is thru the roof. There is a need for ALL the cars that are on display inside the Hall at (Western Auto Salon) to be place ontop of a cover (due to oil leaks and yes noone car does). SO, every car that is part of the display with have to get a "MAT' to place their car on. In staying with the "RACE" theme I will be getting some black/white chequer kitchen vinyl to place under my car, this is going to cost around $15 a meter so it is a small cost compaired to $2000 for the whole area to be done. See what you can do or maybe you have some different Ideas for this problem.
See ya alls in a week when I get back from the EAST.
hehehehe NEW RICER STICKERS should be here by then yeah.
:P
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
