  • Replies 504
Originally posted by GTS-t VSPEC
Erik, Read my new sticker thread, and no nothing in life is free:p
STICKERS!!!!!!!
Did some say something about STICKERS. Arrrgh yes more RICE hehehehe.
Car gets DE-RICED soon :) not for long, new ones here next week :)
thats not too bad ..... half price i guess :)
I would check with Danny he got my shirt too .... probably did but just n case you dont want to get them all back and be missing one .... too late by then
Hi Paul and eveyone,
Right, I did some checking with regards to floor coverings and the price is thru the roof. There is a need for ALL the cars that are on display inside the Hall at (Western Auto Salon) to be place ontop of a cover (due to oil leaks and yes noone car does). SO, every car that is part of the display with have to get a "MAT' to place their car on. In staying with the "RACE" theme I will be getting some black/white chequer kitchen vinyl to place under my car, this is going to cost around $15 a meter so it is a small cost compaired to $2000 for the whole area to be done. See what you can do or maybe you have some different Ideas for this problem.
See ya alls in a week when I get back from the EAST.
hehehehe NEW RICER STICKERS should be here by then yeah.
:P
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
