hi all, just checking that the direction that oil flows through an oil filter is from the outside to the inside? particularly on an sr20det?
also when running an oil cooler and filter relo kit you would have the lines organised in directions as follows -
from engine to filter, filter to cooler and cooler to engine, correct? cheers
https://www.sau.com.au/forums/topic/219818-oil-filter-flow-direction/
as in, would you have the oil going to the cooler first or the filter first, i don't have an oil temperature gauge but ifi did i would want the cooler first as i would have the sensor attached at the oil filter and would want to know my "cooled" oil temperature, but seeing ahow i don't i thought it might make more sense to have the filter first to keep anything out of as much of the lines as possible. or does it just not matter at all
Ah right, sorry didn't bother as Dave answered you :laugh:
I think you'll find ppl always run the filter (and a oilstat if being used) before the cooler.
I know what your saying about temp sender location, but the oil eventually ends up in the sump, which is effectively a wet sumps "reservoir" A sender in the sump would give the hottest temp the oil should ever reach; hence why some ppl prefer that location.
Much of a muchness i think.
i suppose you really would be wanting to monitor how hot the oil is coming out of the engine not how 'cool' (yet still obviously very hot) it is going back in, i don't know why but i had two mechanics tell me that the oil goes into the centre of the filter first and then out of the outside so i hooked my lines up accordingly, but looking at it now it doesn't really matter i suppose
^^ Hrmm all the cars iv worked on have engine oil go into the outer, then out from the center. Time to smack your mechanic :laugh:
EDIT: Found a nice little DIY on SAU HERE for ya.
Any questioning is rendered moot, as you can just have someone keep on eye on both lines, when you crank the car first time; then attach as appropriate.
Edited by GeeTR
kick your mech in the balls.... that setup will create flow issues and result in near ZERO oil pressure if it has a thermostat like a GREDDY cooler etc
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
