Hey guys,
Im just wondering how easy it is to remove the cam gear cover. Id assume its just a few bolts here an there but i am concerned that if i remove the cover, will it move or alter any of the gears?
Can i just remove the cover, then simply put it back on without anything changing?
I had a search for it but couldnt find any answers if it is a simple remove and put back on. I would assume it is?
Thanks
Edited by Ricos
as someone else said when u remove the cover make sure that u make a mark where it goes back. i no someone that took theres off to show there pretty cam gears had no idea where it went and by accident advanced the f**k outta the time and drove it round for a few weeks wondering what that rattling noise was"pinging like a bastard".
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
