what format is it?
save it as a jpeg and it will result in a dramatically smaller file size, with almost no loss of quality
They are saved as a Jpeg file already
I just went and checked
I have already uploaded the files to my computer.
So i dont know what to do. Im not that good with computers and so forth.
I don't know how others do it, but I just right click the image you want to resize, edit, it will open up in MS Paint, then go to the top drop down box thingy and click "image", then "stretch/skew", then just type in a percentage of what you want left of the original image in both the horizontal and vertical, then "ok".
If you end up resizing it too much, just press, "ctrl" and "z" at the same time to redo.
I'm the biggest computer noob I know, so if there's a better way of resizing images, let me know. hahaha
Thats what i do a well. Seems easy and simple and doesnt seem to do anything to the quality of the image.
go to www.photobucket.com
create an account
upload the picture it will resize it for you.
imageshack > photobucket
http://www.imageshack.us/
:D
always ALWAYS have a copy of Photoshop handy
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
