Hey all, i was just wondering what people opinions are blocking off the vacum hose on the stock bov to get flutter..
I did it cause the i like the sound of the flutter =] and i dont wanna get defected for a bov, but i still wanna keep it half safe with the bov opening up after high revs...
But i dont know to much about it ive spoken to some people about it on NS and they said its fine to do. Id just like to go over it with some people that own skylines not silvias haha.
https://www.sau.com.au/forums/topic/220311-stock-bov-with-flutter/
before anyone starts dissing this flamin mongrel i rkn his asking a legit question....so i hope mods give out warns accordingly.
to answer your question, unfortunately you cant adjust what level the bov will open with the factory setup. if you want that lesure u need to get a aftermarket BOV. but then it wont flutter as loudly, and like u said can get defects. if you get a legal aftermarket BOV, you wont get flutter because it redirecting the air back into your intake.
if your cars mostly factory then its fine to just block off your current bov with some aluminum casing from coke cans or something. just got out wat you need and put it inbetween your bov and your throttle body.
heres also a old pic of my engine when i put my 1st bov on. i know its not factory but its the same shit. hope it makes some sense.
personaly on my car ive notice it to be a bit more responsive when blocking my bov off because i always suspected the factory bov to leak under high boost. so this is a great way to fix it
on the other hand.......
alot of people on here will tell you its bad for your turbo, its bad for ur engine this and that. unfortuantely there isnt any proof that its real. theres 8second cars out there running no BOV at all, and are yet to even have the smallest engine problem. but some ppl do and they blame it on blocking there bov.....
my advice is.......its a good way not to get dicked by the cops, and have at least some sort of decent noise when backing off. i dont care wat anyone says its 10x better then the lame "woosh" that factory BOVs have.
alot of ppl here really have a anti-flutter attitude and i guess u gotta expect it if ur gonna follow this path.
if u need more in detail let me know.
Edited by R34NRG
a VERY decent adjustable replacement BOV/Bypass valve is the product offered by Turbo XS, they do a direct bolt-on replacement with adjustable spring tension, etc and it's also rated up to 32PSI before it's "suspected" to leak.
I will be swapping to this product shortly from the stock GTR bypass valve, have seen this product used on the Mazda MPS vehicles, and it makes a massive difference over their plastic valve setups, not sure how it will go on the R32 Skyline, but they offer a direct true bolt-on replacement.
B.
This is a highly recommended modification to the standard turbocharger recirculation system. It will not void any warranty or factory backed warranty agreements. This modification is likely to increase the life of the turbocharger and coincidently circumvents the many many hours of research and development that was undertaken to increase turbocharger life expectancy. After the mid 80s turbocharger life expectancy was around 50,000 kms, after research and development, the factory recirculation system was developed, but its recommend that you circumvent this system to provide 1980 style life expectancy of the factory turbocharger system. All of the high performance work shops recommend this modification to increase street cred, horsepower, torque on the dyno and your custom user rating in points.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
