Hey all.
Any southeners after some spare change one weekend?
I ordered an HKS Heavy Duty adjustable turbocharger actuator of Nengun last August and received it in December. 5 months later I still cant see when it would get fitted.
Are there any handy-andy's down south who wouldnt mind getting their hands dirty for a) $70 cash?, b) or 2x bottle of spirits such as Jim Beam, c) or a premium case of beer, to install the hks turbo actuator for me? Just too hard on my knees to bend over the bonnet and work on the car with no kneecaps..... last time I installed splitfires (1 month ago) I was ruined for a week lol.
Ive got some tools, fairly basic, and got room in the garage out of wind/rain etc. Live in morphett vale and am a very friendly host, the water billy can be fired up & passed around no worries :D
Just after one southener who wouldnt mind sparing an hour of his/her time, for shop rates (boostwerks is around $70 for an hour) and I cant see why the actuator would be more than an hour to install and set to 1 bar?
https://www.sau.com.au/forums/topic/220544-turbo-actuator/
Brenden, when you looking to do this? I should be free June 14/15 if you want a hand then. If beforehand, someone else should be able to help you.
I have the R33 workshop manual still too, so should make working things out rather easy :D
https://www.sau.com.au/forums/topic/220544-turbo-actuator/#findComment-3889070
Its a standard RB25 turbo, but highflowed front and rear housings by Sliding Performance, with oil/water journal bearing centre.
Using stock rb25 actuator atm.
How much did the highflowing cost ya tangles....and what are the benefits of getting that done!
BTW the bov is f**kn awesome mate no probs whatsoever
https://www.sau.com.au/forums/topic/220544-turbo-actuator/#findComment-3889177
It's either a 1 bar actuator which means no need to use a bleed valve to run the desired 1 bar, or For Example, Spike can be caused with a standard 4-5psi actuator because the bleed valve needs to work alot harder to bleed alot more air to reach the desired psi, where as say a 10psi actuator is already close enough to the 1 bar mark so therefore doesn't need as much bleeding hence less spike.
https://www.sau.com.au/forums/topic/220544-turbo-actuator/#findComment-3889200
Done Ryan!!
sweeet ! cheers matey, if youve done it before should be all good.
its a 1bar (14.7) actuator, and Im tuned for 1bar as well with a dual stage ebc (albeit drops to 12 psi, hence this actuator needs to be installed).
sending you a PM, cheers for offering
https://www.sau.com.au/forums/topic/220544-turbo-actuator/#findComment-3889222
hey Krishy!
yeah the highflows arnt done by Slide anymore, unfortunately.
I got a good deal, supplied 2x ruined turbos and some cash (under 700) for the highflowed turbo, steel wheels, 360deg bush bearing, oil and water cooled, rated 250rwkw at 1bar.
Other shops do similar highflows, journal bearing, for around 1300.
Glad to hear the BOV is good, sounds pretty cool hey! I miss it :down:
Rub's, yeah mate has an Apexi mechanical boost guage. Ryan says he's done heaps before, and if he doesnt mind a drive and a billy and a gift of a) b) or c) then its all looking good atm. sent a PM ryan. :bunny:
https://www.sau.com.au/forums/topic/220544-turbo-actuator/#findComment-3889239
yeah the slide-highflows are pretty decent
mines just a stage "2" highflow, the stage "3" has the VG30 rear housing
my inlet and exhaust have been ported to the extreme !
ryan, Ive got some tools (you'd probably want to bring some of your trusties along tho), a real good jack, and some dodgy wheel ramps if needed. only thing is with no kneecaps I cant kneel or squat or stuff like that :bunny:
https://www.sau.com.au/forums/topic/220544-turbo-actuator/#findComment-3889484
'sif I can trust you, lol
:bunny:
your pc will never be ready anyways
I gave you a dodgy list lol, the items you bought wont work together !!!
muauahahahahahahaha
<evil laugh>
why no Mr Bond, I expect you to dieeeee
https://www.sau.com.au/forums/topic/220544-turbo-actuator/#findComment-3889513
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
