79 on 280ZX was EFI in Oz and if your looking at n/a, the best bits are N42, but the block has to be modified to front sump as all zeds are rear sump pans.
Don't be fooled, the old L28, makes good power if modified a bit.
A stock RB30E is rated at 114kW at the fly and an L28E is rated at about 103kW so there isn't heaps in it.
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3895099
will the sump off the L24 bolt onto the L28 block??
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3895625
RB bolts straight onto r30 crossmember wit RB mounts. no probs. hardest thing is gearbox mount.... then tailshaft....
This is true, but there is no clearance from the sump to the x-member. Thats what i had found in my case.
So you can do it this way, it does work, but no one will engineer it. So technically you will never be able to register that car.
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3898487
maybe... mine has ample clearance, it all comes down to the angle the motor sits on.. i cant c why it cannot be engineerd as there is no welding or modifications to the crossmember or the mounts..
ne way just got a blue slip wit rb25 numbers so to the untrained the motor came out in that car. true ?
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3898649
No Hi Horse this time ............................ just quoting FACT! but obviously it's not the answer you were looking for.
Before I answered you before I consulted an old business associate, he is a current RTA registered examination/inspection station and was an RTA examiner before that, so I guess he should know his stuff when it comes to NSW registration. They (RTA) have all the books for all the models and what is or isn't or was or wasn't fitted to the car, but, as I guess you know everything so do as you please.
JFYI, what happens when you have an accident & maybe injure or kill someone with your DODGY registered car and you are sewed for damages by the CTP insurance company??????? You would need millions behind you as any insurance would become null & void when they find your car is illegal.
But you know all the answers eh! and it will never happen to you? ha ha ha ha, go and grow up!
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3900466
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
