79 on 280ZX was EFI in Oz and if your looking at n/a, the best bits are N42, but the block has to be modified to front sump as all zeds are rear sump pans.
Don't be fooled, the old L28, makes good power if modified a bit.
A stock RB30E is rated at 114kW at the fly and an L28E is rated at about 103kW so there isn't heaps in it.
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3895099
will the sump off the L24 bolt onto the L28 block??
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3895625
RB bolts straight onto r30 crossmember wit RB mounts. no probs. hardest thing is gearbox mount.... then tailshaft....
This is true, but there is no clearance from the sump to the x-member. Thats what i had found in my case.
So you can do it this way, it does work, but no one will engineer it. So technically you will never be able to register that car.
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3898487
maybe... mine has ample clearance, it all comes down to the angle the motor sits on.. i cant c why it cannot be engineerd as there is no welding or modifications to the crossmember or the mounts..
ne way just got a blue slip wit rb25 numbers so to the untrained the motor came out in that car. true ?
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3898649
No Hi Horse this time ............................ just quoting FACT! but obviously it's not the answer you were looking for.
Before I answered you before I consulted an old business associate, he is a current RTA registered examination/inspection station and was an RTA examiner before that, so I guess he should know his stuff when it comes to NSW registration. They (RTA) have all the books for all the models and what is or isn't or was or wasn't fitted to the car, but, as I guess you know everything so do as you please.
JFYI, what happens when you have an accident & maybe injure or kill someone with your DODGY registered car and you are sewed for damages by the CTP insurance company??????? You would need millions behind you as any insurance would become null & void when they find your car is illegal.
But you know all the answers eh! and it will never happen to you? ha ha ha ha, go and grow up!
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3900466
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
