as implied above, i have a tv installed in my car but don't know how to tune it...
do i need an aerial or whatever?
i don't know what i need, basically, i have a tv that flips out when i tell it to but only has two channels, AV1 and wait for it... AV2
how do i get normal tv channels, i am n00b hence the question, you guys just know i'd appreciate all the help in the world and i would love it if you could just tell me what i'd have to do to get it working, cheers
Andrew :)
https://www.sau.com.au/forums/topic/220723-tv-tuner/
You'd need a TV Tuner & AV Adapter for it, and also an External TV Aerial that plugs into the aerial connection that's on the Tuner Box.
If it had TV Antenna Input straight away on the unit, that'd make things a whole lot easier lol.
Edited by Magic
https://www.sau.com.au/forums/topic/220723-tv-tuner/#findComment-3892399
is it a jap tv, if so you need a ntsc to pal converter. i had one originally in mine but it was too hard and bulky to get going. also due to the distance the main tv stations are away. tv antennas in your car don't work to well. only thing i done was hooked up a portable dvd player that could play ntsc.
https://www.sau.com.au/forums/topic/220723-tv-tuner/#findComment-3892516
China is mainland...
it's from Hong Kong BAHAHAHA
okay so this is an LCD screen that does sh*t is it?
time to upload videos on to my ipod and play that then, so angry, waste of money LOL
swear it's a tv, what the hell are the channel +/- buttons for
Edited by hoony
https://www.sau.com.au/forums/topic/220723-tv-tuner/#findComment-3893243
Connector: acc power (red) audio/video (AV) input connect, the rich connect outside the input of power = negative on TV capability, unless you do what I said, which involves buying more stuff and will be a real headfcuk, and even then no gurantee you'll get good reception from it. :D
Edited by Magic
https://www.sau.com.au/forums/topic/220723-tv-tuner/#findComment-3893566
dont feel to bad. i paid 80 bux for a power fc program that was sent to me by email. and i dont even have a power fc (thought it was the pfc i was buying, from import monster). that hurt :(
mate sorry but
bahahahahhahahhahahahahahahah
*wipes tear*
that just made my day
https://www.sau.com.au/forums/topic/220723-tv-tuner/#findComment-3896774
Bahaha. Good work Eric! Gotta read that fine print!
Andrew... buy a DVD head unit without a screen, get an Alpine one that can use you iPod more efficiantly (thru the head unit itself) plus all the tuning and that, and just plug it into you head unit.
Having said that... Often it is better to go for the more expensive and safe option rather then the cheap and "easy" way out!
https://www.sau.com.au/forums/topic/220723-tv-tuner/#findComment-3896841
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
