I thought i might post up what a have, make it quicker for someone to find the parts instead of asking and waiting.
I have stock r34 suspension
Stock r34 front pipe/dump pipe
Stock r34 5 stud rims, tires need changing to be legal
If i have anything else ill add later.
Heyyyyy mate im all new to this, a week ago i have just brought an imported r34 skyline from victoria though it got approval over there when i took it to regency ( motor identification place ) they failed the check due to some parts tht i need to either replace or take off so i was really hoping if anyone from adelaide would be able to hlp me if they have standard parts if i could borrow them for a couple hours just to get it registered it would mean alot since im really stuck thank guys
the parts i need to change are:
i need standard tyres for an r34 as mine art the right sizes
i need standard suspension as mines automatic coil overs
and also a standard r34 exhuast as at the moment i have a hks exhaust on it
though i also got done for having a turbo timer and blow off valve i can just take those off
if anyones i little hesident on leding the parts i can leave a deposit in your hands jst until i get it registered or i can leave my parts with you ;)
Hi, as it seems the cops are going crazy on the defect lately, at the request of some users I have created and stickied this 'Wanted to Borrow' thread.
Feel free to post in here if you need items to borrow to get off defect or through Regency.
heyyy mate i realllllly need help in finding stock suspension to borrow so i can get my car through regency cause atm iv got auto coil overs its for my 2 dr r34 gt t cheeers hpz
Hey All, new to SAU as just got my gtst r33 couple mths ago. Got defected the other day, for being to low. Which it wasn't, just had know way to prove him wrong. he would have done me for something else anyway. I'm looking to borrow or buy a set of r33 stock suspension, stock BOV and boost solonoid. If anyone can help plz let me know
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
