Item: R32-33 gts-t just jap front pipe dump pipe in 1 Stainless
Age: 6-7 months
Condition: Good
Price: 160 pick up 185 posted
To Fit: 32,33 gts-t
Contact: PM or 0438804282
Comments: Good nick had it on the car got an extra .5-1psi extra with stock turbo
Item: R32 Hicas pump and front and rear lines X2
Age: 18 years
Condition: Good
Price: 30 pick up 55 posted
To Fit: R32 All
Comments: Dont need fitted lock bar
Item: R31, 32, 33, 34 Stainless intake pipe
Age: 1 years
Condition: Good
Price: 70 pick up 85 posted
To Fit: 31,32,33,34 gts-t make it fit what you want
Comments: Brought it off a mate and decided not to use it. i have never used it and he didnt have it on for long
Item: Blitz BOV
Age: 5 years maybe
Condition: Good
Price: 100 pick up 115 posted
Comments: Came with my half cut and i used the pipe off it.
Item: R32 GTS-4/GTR Steering Rack
Age: 18 years
Condition: Good
Price: 120 pick up 150 posted
To Fit: R32 GTS-4/GTR
Item: R32,33 Standard dump pipe
Age: 18 years
Condition: Good
Price: 20 pick up 40 posted
To Fit: R32,33
Item: R32,33 Standard side mount intercooler
Age: 18 years
Condition: Good
Price: 70 pick up 90 posted
To Fit: R32,33
Item: R32 Black LHS gaurd DAMAGED will get pics up this weekend
Age: 18 years Condition: DAMAGED but repairable
Price: 30 pick up 60 posted
To Fit: R32
  • Replies 44
Is there a difference between the GTR/GTS4 Steering rack and the GTST?
Shaw is mate if you dont want the front shaft in your gts4 gtr then a gts one will fit but if you do then you will need a gtr/gts4 one
thats cheap, blitz bov $100.... come on guys, @ this price, it wont be here for long..
i know people who paid alot more theirs lol...
GL with the Sale mate.
Thanks mate i dont really want to use it and i have seen them go for 150+
Cheers
will that s/s intake pipe fit straight onto a rb20det with std rb25 turbo on it running std afm and std
airbox? are the nipple things on it in correct location for a rather stock set up?
Cheers
Also got my eye on that combined dump & front pipe.
Thanks
Cheers
Thanks
Got no idea if it will fit i got it off a bloke who was running a pod but i do think you could get it to fit they are in a similar spot, i have a bloke interested in it but i will let you know.
The front/dump pipe has been sold went today sorry should have updated it
  • 3 weeks later...
Hey buddy,
Just called you but i didnt pick up ur phone. it was in regards to the BOV? If you havent sold it!
I've still got the stock BOV and all i have to do is remove it and attach this one... and im guessing the BOV ur selling comes with the adaptor? Loud noise or what??
Cheers
Hey buddy,
Cheers
Hey Mate,
Just returned your call.
What you see in the photo is what you get this came on a cooler pipe in a half cut i got i used the cooler pipe off it.
The addaptors are sold at autobarn for around 20-30 $$ i think and the BOV are around the 200 mark i think.
I never used it but i think they are loud
Let me know if you are interested
  • 1 month later...
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
