Hiya, I've just found out that no-one in England can map a PowerFC for a R34 GTT because no-one has the right "lead" to connect it to a laptop (they can map GTR's but the GTT use's a different FC Commander version and needs a new lead to communicate with the laptop) and can only use the FC Commander which isn't ideal. Is there anyone who can get me a lead or tell me where to find one as I assume that your tuners have the right leads as they can map your GTT's.
Any help is greatly appreciated and you'll be able to help map the 1st GTT in the UK!
Cheers......................................................IanH
https://www.sau.com.au/forums/topic/22102-r34-gtt-and-powerfc-question/
Hi IanH, we use the Commander to tune Power FC's. I have only ever seen two types of Commanders for R34's 415-N001 or 415-X001.
http://www.meggala.com/powerfcmodel.html
The above link shows the PFC and Commander models for each vehicle, it might help.
Datalogit have a porgram for laptops to tune (and data log) but as far as I know it is only available for GTR's at the moment.
Apexi Power Excel dealers in Japan have laptop programs supplied by Apexi, but the licence fees are expensive. I don't know of anyone In Australia that is a licensed Excel shop.
Hope that is of some use
Thanks SydneyKid - The GTT needs the N001 Commander and I was sent the X001 so I'll have to change that anyway. Even with the right Commander there is still no-way to connect a laptop (and Commander won't be as good). I'm in contact with Datalogit about a GTT version so I'll let you know later how that goes.
Cheers anyway.....................................................IanH
  • 4 months later...
Ian, did you ever hear back from them about a GTT version? I'm probably going to be buying a GTT in the near future and I was hoping to get it mapped with the Datalogit software.
Cheers,
Michael
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
