just changed my dashboard cluster globes with leds tonight and thought I'd clean up that clear plastic cover that covers all the gauges .. Turns out the stuff can't be cleaed. Looks like someone had sprayed some sort of clearning detergen over the clear cover and didn't wipe it off and it just won't come off ... like the plastic is ruined (although it feels smooth on touch)
Anyway was wondering if there are any skyline wreckers in sydney ? This is for an R34 GTT... or if anyone has any suggestions on what to try and clean this crap off with, I'm all ears. I've tried standard detergent, alcohol etc and the stains won't budge
https://www.sau.com.au/forums/topic/221545-skyline-wreckers-in-sydney/
give it a cut and buff we used to do it all the time
cause when we had dashes out at panel shops the idiot beaters used to spill all kinds of shit on em (brake, fluid thinners, etc, etc)
quick wet sand with some 1500 and then run the buff over it and it should be fine
Ok I've tried 5 different cleaners and none seem to be able to get rid of this crap (even tried Maguires ScratchX .. which btw is a useless product - doesn't do crap on paint scratches either)
Abo Bob, is it unblemished and fits a GTT ? If so, do you want to sell it and if so how much? :thumbsup:
Forget the cleaner products they won't work.
Follow Dahtone Racing's instructions and you will find your cluster will be fine.
Wet sand with 1500 as he said.
Then polish it.
Don't bother with cleaners.
Abo Bob, is it unblemished and fits a GTT ? If so, do you want to sell it and if so how much? :P
Maguires ScratchX worked fine on my headlights to get rid of the yellow haze, though I used it to buff out scratches left behind by 2000 grit abrasive paper.
Wet sand with 1500 as he said and hand polish with Maguires's plastic polish (can't remember the name)..
ScratchX mentioned earlier will work as a plastic polish, but I believe Maguires PlasticX is what your thinking about :)
can someone just quickly explain to me what 'wet sanding' means ... just what it says ie. poor water over the plastic whilst sanding it ? What does this achieve?
You keep the item you are sanding and the paper wet. It makes the sand paper less abrasive and therefore leaves finer scratches. The idea of sanding is to start with a more abrasive paper and finishing off with a polish. In English you sand the big lumps off first and work your way down to the small ones :D
Try Brasso buy it from supermarkets. Have used it for years to clean perspex, polishes alloy wheels perfectly. Don't waste your money with the fancy named brands- try it you won't be dissapointed-its cheap.
You may need to use wet and dry if you panel is badly marked-I would use 2000 then brasso.
headlight repair kit to fix what ? the yellow headlight haze someone mentioned or the clear cluster plastic ??
To do either, esentially its doing the same thing. Making plastic go from that dirty opaque look to a clean clear look by removing layers of plastic. I have to tell you though to patient with it. Results aren't instant and the longer you take polishing them up the better they will look. :)
Damn! Why didn't I think of Brasso :) I'll have to keep that in mind for when my headlights get eventually yellowed again and I run out of ScratchX :)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
