Hey Guys,
Just thought I'd share a bit :D
About a week ago I ordered a new clutch kit from the US, and finally got around to installing it yesterday.
The verdict - WOW
I can't believe how much more pull the car now has. My stock clutch was doing fine and not slipping at all, but it was getting on.
I was considering a few different brands, and in the end went with the JWT kit.
Consisted of
JWT Clucth
JWT Lightened Flywheel
Stainless Steel braided clutch line
Chromoly clutch pivot ball
Nismo roller bearing
The end result is a much much better feel when driving. The lightened flywheel is a tiny bit noiser than stock, but it definately gets the car reving faster. It just feels like it has so much more oomph than it did before. Still haven't given it a hard workout as I want to put a few more k's on it first.
As a bonus, the apprentice at my mates workshop drained my tranny fluid by mistake so this was replaced as well with Redline MTL :-)
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/
Jas - sort of, haven't really had any decent hills as such, but it feels like that across the board. In every gear, a stab at the throttle and it jsut moves!
GEXer - definately smoother. Especially first to second. Not sure why this is, could be cause the old clutch was as i said getting on, but with the new one, all gears move in and out smoother.
The rattle is there when idling and when in the low rpm range. For example if I'm lazy and go around a corner slowly in 3rd in stead of changing down to 2nd, you definately hear the rattle until you get back up to around 2200rpm. Nothing while cruising though.
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3906297
A bit of rattle is a small price to pay... Sounds like it was well worth it.
What sort of cost was it??
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3906306
To me definately was Micah. The rattle takes away a bit of the "luxury" car feel, but to me the car was never a "luxury" car in the first place. Feels more "brutal" now :down:
All up installed it cost me $1200. Which is pretty good. Any local options would have cost around that much before install.
The exedy I was looking at was over $1200 for just the clutch and flywheel and would have come to over $1500 with the rest and install.
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3906322
That's fantastic: I just paid trade price of $1600 for a clutch for the stag, and that's supply only... And I know what you mean: my stagea is by no means an easy car to live with: definitely no longer a family wagon! :(
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3906342
Hey Guys,
Just thought I'd share a bit :down:
The verdict - WOW
Consisted of
JWT Clucth
Great, thanks for sharing that. Was the install straightforward - no mods required?
I've always wondered about the tranny on the V35, 1st to 2nd has always been iffy although not a huge problem once you get used to it. I don't know if it's the same with the Z350. How's the clutch, it is 'softer' now and easier to modulate?
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3906408
definately straight foward install. The kit fits V35's and 350z's with no problems. (I bought it from a 350z site)
The pedal is softerish when you just press it but while driving and changing gears it feels more sturdy. The take up is much much lower as well. Manual guys will know the V35 stock clutch engages quite high.
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3906452
Thinking about sourcing this clutch/flywheel combo as well.
I'm looking for a new clutch, since I broke my gearbox, and I was considering a Nismo twin plate Coppermix. Unfortunately the cost is extremely high, as you can imagine, and as I have no goals (or funding) to go forced induction I doubt I need it.
My JUN flywheel rattles like a bitch so I'm not fussed about the noise. How do you find the pedal feel and action? I need to decide on a clutch/flywheel combo soon, so I look forward to hearing about yours.
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3911064
Hey Alan,
The pedal feels softer than stock, but the take up is much lower. On the stock V35 clutch you would letting the pedal out for 1/2 hour before it engaged, where as with JWT it's pretty much immediately. At the same time I haven't given it a decent workout as yet, as wanted to put a few more k's on it.
Where abouts in Syd are you? If we can organise a time, happy for you to check it out.
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3911129
If you dont mind and your in sydney PM me the mechanic who installed all of it for $300?
Hey mate,
The guy who installed it is a mate who has is own gearbox shop in Ingleburn. That price was of course mates rates so not sure what his price to the public would be.
Let me know if you still want some details but pretty sure it wont be $300.
cheers
Bobby
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3911132
Inner city these days.
The car's going to Pro Concept tomorrow so they can drain the gearbox fluid and see what lumpy bits fall out. I'll need to have ordered a clutch within a day or two of that, once I work out what I'm doing.
My head says "Nismo twin plate Coppermix", my heart says "ATS twin plate carbon", but my wallet says "JWT single plate".
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3911226
Go with ur wallet mate :D , A lot of guys on g35driver recommends JWT. If u dont have plans for FI, then there no need to go higher than this...
$300 to install the clutch and flywheel is cheap, can u let us know what Pro Concept charges scathing?
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3911377
I'm no clutch expert, and as much as the JWT is an upgrade on stock, i don't think it's anywhere in the league of the other two. In my case, i went with a clutch for a daily driver and maybe 2 or so track days a year. I'm also still very much a track noob so i doubt i'll be pushing the car anywhere near as much as what you do, and no semis at this stage for me.
What about a decent single from Exedy? "Turbo Spares" in cabramatta has unbelievable prices on exedy clutch's, and can most of them in your hands in 24hrs.
I work in Macquarie park and go home towards liverpool, so if that crosses your path at all, let me know and you can check out the JWT.
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3911405
How does a flywheel rattle? It's a solid piece of steel with a starter motor ring gear shrunk onto it. There isn't anything to rattle, unless the ring gear is loose or the flywheel bolts (to the crank) aren't tight. Either of which is a frightening thought. The pressure plate shouldn't rattle in a single plate clutch, the intermediate plates do that in a multiplate clutch, but there isn't any of them in a single plate. So that leaves the clutch plate itself, the generally only rattle if/when the springs wear loose. Again, not a good thought in a new clutch.
Personally I would be taking it back to whoever installed it and have them stop the rattle, whatever is causing it, as none of the options are particularly appealing for the life of the clutch.
Cheers
Gary
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3912005
Cheers
Gary
Gary, I call it a rattle but it is also referred to as chatter. Should I still be concerned?
Nearly everyone, every post i have read re lightened flywheel, always has an element of "chatter/rattle". It's even there on the stock clutch to some degree.
https://www.sau.com.au/forums/topic/221583-new-clutch-wow/#findComment-3912097
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
