PWND Posted June 2, 2008 Share Posted June 2, 2008 no worries. glad i could help Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3912846 Share on other sites More sharing options...
DosuGTR Posted June 3, 2008 Author Share Posted June 3, 2008 (edited) Just wanted to add, that tomei genesis rb26 looks sweet, too bad its $30,000 but it seems like you can build one just as good or better for half the price Edited June 3, 2008 by DosuGTR Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3913316 Share on other sites More sharing options...
DosuGTR Posted June 4, 2008 Author Share Posted June 4, 2008 When building a gtr for responsivness(track not drag) around 300-350awkw would a 2.8litre engine kit help? Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3919179 Share on other sites More sharing options...
Rolls Posted June 5, 2008 Share Posted June 5, 2008 rb30 would help more and be cheaper. Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3919301 Share on other sites More sharing options...
PM-R33 Posted June 5, 2008 Share Posted June 5, 2008 For only 300-350awkw you wont need the extra displacement for response, it is possible to have that kind of power with small aftermarket twins and still be responsive as hell. However yes it will help. Keep in mind though, for a 2.8L or a RB30 bottem end your looking at anywhere from $5000-$10000 depending on what exactly you want to do. Once you factor in fuel system, turbo (or turbos), ECU, Tomei 2.8 kit ($6000 approx), exhaust, piping, machining, balancing, gaskets, labour, tuning etc etc it starts to add up really quick.... Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3919749 Share on other sites More sharing options...
DosuGTR Posted June 6, 2008 Author Share Posted June 6, 2008 Ah okay, for 350awkw theres no need for a n1 block? getting my stock block machined and then forged pistons/rods ect will do the trick and last long? Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3922751 Share on other sites More sharing options...
PM-R33 Posted June 6, 2008 Share Posted June 6, 2008 Definetely dont need a N1 block. Standard block with forgies will be more than sufficient. Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3922795 Share on other sites More sharing options...
DosuGTR Posted June 6, 2008 Author Share Posted June 6, 2008 When they say balanced engine or full engine balance is that with a harmonic balancer or ati balancer or something? or those are completely different? Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3925409 Share on other sites More sharing options...
-_-StRyDeR-_- Posted June 6, 2008 Share Posted June 6, 2008 a proper balance should be done from the balancer to the clutch. im using a Ross balancer for mine, nice price tag also. Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3925447 Share on other sites More sharing options...
DosuGTR Posted June 6, 2008 Author Share Posted June 6, 2008 So when they talking about balancer or balancing the engine they only mean the part like, ati or ross brand balancer? Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3925466 Share on other sites More sharing options...
700HP-GTR33 Posted June 7, 2008 Share Posted June 7, 2008 Get the car inspected by someone who can tell you... -what injectors are fitted. -what turbo's are fitted. -if there was an after market engine management ever fitted. Besides this..check spark plugs for uneven burn..check radiator for bad colouring..check engine oil level and change ASAP. Replace timing belt...fuel pump..and all oils including diff..gearbox... Oil pump means engine out..so plan to do engine work at the same time You will find some good advice on here on the good oils to use. Also save some pennies for new Turbo's...that is if you don't want engine work earlier. This above items will determine you next steps on making it more reliable as a day to day car. After all of the above has been addressed...save some pennies for a clutch...before 3 Month of driving... if you still have a stock clutch....you will be loosing grip. Jim Berry Clutches.....he will rebuild you stock clutch...do not throw it away. Also keep your exhaust..if it is stock that is. Keep you suspension as well..GTR suspensions are great on the road.....you may just need new shocks at a latter date. Hope I have been of some help. Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3925599 Share on other sites More sharing options...
Swiper the Fox Posted June 7, 2008 Share Posted June 7, 2008 So when they talking about balancer or balancing the engine they only mean the part like, ati or ross brand balancer? each of the reciprocating components is individually weighed and any irregularities are adjusted (by removing material from the heavier ones) the crank is mounted on a balancing machine and spun to measure any problem areas. Material is then removed from it to make it operate true. Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3925630 Share on other sites More sharing options...
700HP-GTR33 Posted June 7, 2008 Share Posted June 7, 2008 each of the reciprocating components is individually weighed and any irregularities are adjusted (by removing material from the heavier ones) the crank is mounted on a balancing machine and spun to measure any problem areas. Material is then removed from it to make it operate true. Engine out.... New oil pump New Balancer. Allow 4K Maybe a new crank..depending on it condition. Allow 1K When motor is out...new Turbo's a must....to difficult when motor is in. Allow another 3K GTR's cost money... Plan your mods.....take it step by step..... Allow for miss...items...... Crank...lol.....that will be the least of your worries.... Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3925645 Share on other sites More sharing options...
DosuGTR Posted June 7, 2008 Author Share Posted June 7, 2008 awesome, you guys are great, i wont feel like a complete noob when i go to a local tuner(just a small noob ) those 3 guages that come over the audio system are they really needed after i buy some ones that are needed for upping the boost? because my car didnt come with them, has some ugly audio system in its place Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3926693 Share on other sites More sharing options...
arep3 Posted June 8, 2008 Share Posted June 8, 2008 the stock gauges in the din slot are fairly crap at the best of times. you will need to know what your motor is doing so get some good gauges. The stock 1s dont read very well Link to comment https://www.sau.com.au/forums/topic/221600-engine-rebuild/page/2/#findComment-3927068 Share on other sites More sharing options...
