the stuff Superior CIA sells is real carbon with little to no fibreglass usage. Its quality stuff with perfect fitment, moulds and cloth. Well worth the squillions of yen they ask for them.
Got the Black Carbon Look Seatcover (front and rear set) and the centre consle carbon fibre cover this morning.
Went to my gf's place and put on back seat cover, but she dosen't have a socket set, so I couldn't do the front seats. :-(
Those seat cover looking f*cking insane!! Well worth the money. The centre console cover looks good when you stand slightly far away from it, but I'm not 100% in love with the pattern, but still looks nicer than stock nevertheless. I'll take some pics in the next a few days. So far, I'm very happy with them :-) Total cost for the seat covers and console cover was around $900 something AUD shipped via EMS.
Nice one! Pics bro pics!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
