are your wheels done up tight?
sadly though this often happens with spacers. the best best is just buy the correct offset wheel and bin the spacers.
spiggots/hub rings will cure that problem, spacers are great for increasing track but bad for this problem and a few others.
you can screw them till the studs break it wont cure the problem, and no a wheel alignment wont help either.
if your im melb give me a buz/pm i can make them up for you ....
sometimes you have to get them made up.
yes some tyre places will have them, but make sure they are a tight fit, there should be no movement when the wheel is on, NO movement other wise you will have the same problem again.
bryyy- your one of the lucky ones :)
Edited by robbieraver
it should do. sorry I just assumed your bolt on spacers have that little 'lip' in the middle to locate the wheel. if not then that is almost certainly why you are having these problems as it's pretty hard to locate the wheel dead centre without the hub ring on the spacer.
if it doesn't look like this, it's not good.
but they do make the wheels stick out a LOT so if your already filling out your guards.........
if your wheel is a standard ID then you can buy off the shelf spiggots for like 20 schmux
i needed custom cause ssr professor sp1's have a weirdo 79mm ID :D
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
