what sound does yours make and how loud ..also this would be legal so no sticker :D
i cant see why it would be illegal??
it just makes a flutter sound, and is a little louder than the standard whoosh from the standard plumb back bov.
also depends on what turbo you are running as to how loud it will be.
  • Replies 48
yer thats sick i had the flutter sound with my atmospheric bov but stalled all tha time so this should be good :D
Cops wont like it but no technically its not a defect..but no doubt they'll get you for exessive noise. Same as bov.
Defects hey .. you know That phat turbo under your hood is .. Probly that high mount you bolted onto it most likely is.. the wastegate you have.. yeah id say so..
Aftermarket exhaust? Yeap
Aftermarket ECU? Hell yes..
Your worried about your noises? lol
Edited by DECIM8
atmoshperic bov are considered noise pollution in SA, not sure bout other states.
thats a load off shitt aye cops are soo gay but will they pull you over to check up on that shit i mean ive been through road blocks and booze busses and they have obveiously heard my pshhht coming down the street and havent said anything .. just luck i guess
u guys are f**kn dickheads. have you guys ever throught that maybe its to cure the bov leak? or maybe it was just easier cuz his running a aftermarket plenum and throttle body. or many other things?
not eveyrone has 500bux to spend on a BOV.....and blocking it gets rid of both defects and keeps boost from leaking out of the factory shit bov. its a cheap and easy thing to do. so i dont know why so many of these f*kheads are splittn more shit on these forums.
i wish there were more mods doin the rounds cuz there are just to many f*kn heros on this board.
well said :D
If your running an AFM, with a blocked off bov, it WILL idle worse and stall under heavy braking (due to extra vacuum).. not fun.
im running a blocked off valve and AFM and dont have any dramas with stalling at all. atmo venting valves are the ones that give dramas stalling
Dumbest thing ive ever heard.. Get a plumb back if youve got a bigger turbo recirculation helps with smoother transition of gears.. blocking off the bov will make the turbo chuff/flutter and make the car feel like its almost going to stop during gear change.
not sure what air your on about.
you have no clue
half these idiots havnt even got 1st hand experience and they talk like they do.
ive had my bov blocked and sporting over 350kw at the wheels. with afms. i dont get stalling issues and i dont have stupid idle problems.
ppl who have these problems dont tune their car.
if you block your BOV, get it tuned to run with a BLOCKED BOV.
GTFO
/rant
GTFO
/rant
i still gotta get mine tuned but my machanic said there was no probs when he tested it and thats untuned
guys, please try and keep the aggressive and abusive posts out of this forum. also, this guy asked a serious question and just posting silly answers does not help, and is not as funny as it may seem in your head. all it does is guarantee the thread goes downhill fast. consider yourselves all given a friendly warning, but continued behaviour like this will result in official warning and eventually posting restriction and banning. So please help me keep the forum friendly and informative. :banana:
now a serious response.
it is actually illegal to remove/block/disable the blow off valve on a car that was fitted with one from the factory (which yours was). Simply because the blow off valve (actually a compressor bypass valve) is part of the factory emissions equipment.
On top of that the flutter noise it makes will attract attention from the police.
I would suggest if you have a problem with your factory GTST BOV leaking then consider upgrading to a standard GTR BOV (32/33/34 are all good). They can be often had quite cheaply, look very factory, flow plenty and can handle plenty of boost without leaking. I would say $50 or $60 would get you one, and from what I understand they are pretty much direct fit.
GTFO
/rant
Its because your cars tuned man, half the guys on here block the blow off valve/go atmo bov then ask 'why is the car stalling, why do I get bad idle' etc etc
I used to get stalling with a blocked bov on stock ECU but not on the Power FC. I also didn't get stalling issues when running an atmo BOV on the Power FC but again thats probably because of the way its tuned
Its probably more to do with the way the stock ECU is tuned, it expects the air to recirculate back from the BOV to the intake and when it doesn't thats when you get stalling etc but who the hell would go get there ECU tuned after blocking there bov? Thats stupid
Your running after market ECU, tune etc thats why you don't get stalling but who the hell is going to block there BOV then go get a tune done just for that?
Majority of people do it on stock ECU, run into stalling issues, idle problems and all the rest of it, then a thread goes up asking why
Actually, I didnt have a BOV fitted to my new forward facing plenum / intercooler piping - I put my foot down around the corner from the garage and my I/C piping blew off!
So im thinking if my piping hadn't blown of under pressure, surely it would hurt the turbo in the long run?
it blew off because you didnt secure it properly. how much pound were u running through the pipes? are there alot of bends?
Hey buddy, adjust your attitude on this forum from here on in, or you will be banned.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
