Hey Boys and Gurlies :)
I need some help, Im getting all painted, and kitted up for autosalon, But unfortuantly im going to be running low of money after all of that is done... i have lil 17's that i think are abig let down to the nice bodywork im getting done, and no where near enuf money to be able to buy a set of rims. So i was wondering, would i possibley be able to borrow some nice person's 18's or 19's just for the show... :D The rims wont be driven on because te car is getting trucked to the venue, so no stress about curb rash or burnouts, wich i wouldnt do anyways...
I'll even say pritty pritty please, and buy you half a carton of watever... oh and lots of huggs haha :)
my number is 0424933728 and im Kels, if any1 could help me out, i would much appreciate it!
Thanks heaps!!!
Xo. Kels
https://www.sau.com.au/forums/topic/222153-rims-4-autosalon-help/
what about a full carton?
lol i'll try and find some for you Kels... i might be entering myself seeing as though i'm doing paint and panel work too... if i don't make it in time you can have my 18''s for the weekend... they should be painted black with a polished lip by then... they'll look like this;
http://www.tirerack.com/images/wheels/zini...8_blk_ci3_l.jpg
never know though you might be able to find some nicer ones... what exactly is getting done though?
i know you're getting that kit from Fibrevision but come on, don't be so 'top secret' with us and fill me in lol
A very low skyline on 17s still looks hot, with 17s you can lower the car further just for the auto salon. Do you have adjustable coilovers by any chance should you not be able to source some 18's?
Nah i dont :D i was thinking, oh ill just lower the car, but then my bill for paint came in :( I dunno my 17's are in imac condition, no curb rash or anything, i just dont think they'll do the car justice on the day... thats why ive opted for 18's, atleast there a bit bigger... lol...
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
