Make: R31 Skyline
Model: 3.0L Excutive
Transmission: RB25DET AUTO
Colour: White over Black
Currently registered? Yes
Price: $3000 ONO
Contact: PM Me to inspect or view pictures
Comments / Modifications:
-New Injectors
-Turbo Conversion (T04E, High Mount Manifold, Front Mount, etc.)
-3 Inch Turbo Back Exhaust
-XF Throttle Body
-RB25T Auto Box
-Boost Controller
-Oil Catch Can
-Blue Plated and Legal
-Freshly Buffed Paint
Comes With:
Complete Spare Rb30 with gasket set
This is one fast R31 and it doesn't attract attention.
The bottom end of the motor is a little tired(rings are gone i believe), hence why I am supplying the other motor with it.
Had it Checked out a Goodyear for a major service...
A few things they listed that need replacing:
-Fan Belts
-Bump Stops
-Front Struts
-Wheel Alignment
Any questions feel free to ask...
Cheers.
Brad
https://www.sau.com.au/forums/topic/222268-turbo-r31/
