Hi guys!!!
please need to help with choice, i wrote before in several topics regarding my problem, am asking because here is nobody who can tune fc, as some kind people suggest i need to buy Datalogit for fc but its costs not cheap:) almost same price that Emanage ultimate, so please suggest what to do by datalogit or another ecu:) anyway i could not tune it my self and i need to ask someone or pay money to do it, or if someone knows good way to helpm me please help... fc is absolutle not tuned and car makes last time till 90 knock for one runup i know its not good and dont wanna kill engine, i have next options on car R33 GTST 93 y. model
stock pump
stock injectors
stock AFM
3.5" full hightflow exhaust
Intecooler 600X300X78
FC comander not tuned:)
KKR480 TURBO
Front mount plenum
and fuel pressure regulator
and that all
because of i cant manage more boost on turbo i haveto open westgeit fully now turbo spools at 4500 RPM and have top boost 16 PSi, car is mach better than stock 1/4 mile for 12.85 but still not tuned and last time knokc are more than before i think that for hot air temp. and before just doing next mod on FC changing ignition timing for 6 degrees and thats all
please help what to do!
https://www.sau.com.au/forums/topic/222382-pfc-or-emanage-ultimate/
learn how to tune the powerfc, you would be mad to sell your current powerfc and replace it with a stock ecu and emanage
you just need to read and take some time to understand how to fix the tune and knocking and get the rest out of the tune
all of the documentation is there, read the PFC FAQ, read the whole thing, it will cover most things you are trying to do
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
You should keep your Power FC.
If you buy a Datalogit and a Tech Edge air fuel ratio meter I will show you how to set it up for logging, email me your map and your logs and I can tune your car for you from here.
It will cost a bit to get the bits you need but will be well worth it.
I'm an emanage nut (but tune just as many PFC) and i reckon buy the datalogit ;) you already have a great computer no need to pull it out. The emanage is killer but if people are struggling to tune something as simple as a PFC i am worried they will have an aneurysm with the EMU ):
hey mate, in the magazine 'High performance IMPORTS' issue no. 93, it has a write up on how to tune a pfc. try to google the mag and see if you can get a copy sent to you, or pm me and ill scan the pages and e-mail it to you.
Hi mate, can you do this favor for me ? thanks in advanced
P.S please suggest where to buy datalogit :P
and guys can you tell me what boostcontroller connects to FC? or what solenoid needed? or better to buy nef controller?
Edited by guricha
P.S please suggest where to buy datalogit :)
www.fc-datalogit.co.nz
i wrote them sevral times but no naswer from them still:(
Today I have installed PLX 300 wideband gauge, it shows 11-12 what you think its ok? still have knoking lever till 90, hope buy datalogit asap than maybe you can help me:)
Edited by guricha
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
