Item: gts-t bonnet, black
Age: 18yrs
Condition: immaculate perfect condition
Price: $250
To Fit: (What car) r32 gts-t
Contact: ben via pm or 0412920293
Comments: prefer local pick up only, as its rather large
Item: left and right hand guards, black
Age: 18yrs
Condition: average
Price: $150 for the pair
To Fit: (What car) R32 gts-t
Comments: guards have been lipped and pumped out fairly wide. i had 17x8+5's with 225/45 fitting well just under the guard
guards are in fair condition, have small dents from indicators flapping around. wouldnt hurt to give them a lick of paint altho u would be able to use them as is. guards were pumped proffessionaly by 'adelaide radial tyre' with their guard roller.
Item: r32 gtst clear front indicators left and right
Age: 18yrs maybe less
Condition: awesome condition, onli down fall is the top brackets are broken. easily mounted other ways i can explain if needed
Price: $100
To Fit: (What car) r32 gtst
Comments: um... yer get some nice clear indicators... you know u want them.
Item: R200 shimmed viscous diff centre with shafts
Age: 18yrs maybe less, has onli been shimmed for approx 5000 k's
Condition: awesome condition, nice and tight
Price: $150
To Fit: (What car) all the usual nissan r200 stuff
Comments:
Item: R33 rear diff housing non hicas, housing only
Age: no idea
Condition: as good as a diff housing can get lol
Price: $50
To Fit: (What car)
Comments: um... what else is there to know?
https://www.sau.com.au/forums/topic/222388-r32-gtst-bonnet-and-guards/
the guards arent really worth sending interstate guys. wouldnt be cost effective, by the time u package mine up and pay for transport you may aswell buy them locally in nsw/qld wherever u are.
in my opinion they are not worth sending - but if u insist, you organise something, get your own prices and if ur still realli keen we can organise something
