hey all
madaz r33 has given me a good plan for the cruise, seeing as we're all from the burnie area apart from him, he suggested that we start in devonport then have a run through some of the back roads on the way back to burnie then cruise through burnie itself. let me know what you guys think
cheers adam
  • Replies 72
Posted Images
Keen for anything. Back roads are for tractor's tho imo
^^ Watch you talkin bout willis? my g/f's parents used to own property at natone, the drive up from Minna road through natone and stowport is sick imo. (or even going towards burnie and turning up the hill as just get into burnie that has the dogs home there, forget the turn off road name) I used to wind my old Rx7 out on some of those straights(although speedo stopped at 180 and i'm not sugesting we do that!) heaps of wicked sweeping corners, its a good drive along that area. Mind you on the very odd occasion an old farmer would be putting around on his tractor, all of the farmers were pretty cool and always pulled to the side asap to let me through. Damo
Edited by madaz R33
well i think everyone has decided cruise through burnie and up some back roads. as for speed just doin 100 through some of those corners is fast enough to have some fun. i mean a day at the track would be fun but it's a long way to travel
all good, lets do it, most people on the NW would be moderately happy with the suggestions, it will do for our first NW cruise, Elaborate on further cruises if people show up to this one and its a success.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
