  • Replies 68
Posted Images
Yeah, i think theyre 3/8 in diameter or something like that. They couldnt be in a better place really. Silly to run braid or any other solid line under the car if these are unused.
Shaun.
Whats wrong with just using the standard fuel lines under the car? Thats what i did, my setup is the blue skyline in the first post of this thread.
Edited by Gts30t
Can you remember the exact fittings you used to hook the braided lines up to the stock hard lines?
  • 3 weeks later...
That was my first thought, however I find that most of the time it looks really messy or disorganised. I'm thinking of running them underneath the fuel rail through cable holders (similar to what's used for computer cables or home entertainment cables) so that I don't have zip ties and plastic conduit going everywhere.
  • 3 weeks later...
Some very serious filtration going on there.
Are you running one tank for methanol/race fuel and the other tank for normal duties? As it looks like you have a distribution block that links to the fuel lines that run underneath the car?
u guessed it!
the sard surge tank is connected to the standard fuel tank which will be used for ur normal every day 98 octane
the fuel cell will be used for race fuel
the car is setup so it can swap between different fuel's via a switch inside the cabin
we are able to do this because the haltech E11v2 allows us to hold more then one tune map
so with a flick of a switch we can go from street mode to race mode
the wiring involved thats going into a setup like this is just mind blowing
the fuel cell is a custom item which we blue printed from the sard surge tank
we bought the sard surge tank from hi octane and copied its design and built our fuel cell from it
so not only is it a fuel cell its also a surge tank all in 1
the filler cap and lid are all CNC machined from billet
we will also be making our own sard surge tank copy's which we will have on the market for less then geniune sard items and they will perform just as good
  • 4 weeks later...
  • 10 months later...
Fuel system i recently did for a mates 33gtr im building.
For the fuel pump wiring, i used 2 30amp fused relays, 1 for each pump. Power is connected straight to the battery, and the trigger for the relays is spliced into the factory harness, its the wire that goes down into the fuel tank, its a switched 12v that powers on when u flick the key, easy to find with a multi.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
