I am looking a getting a new cat.
But when i looked at the one on the car i found this
just wondering what this is, and if i need it as the new cat does not seem to have a place to fit this sensor?
by the way it's a x force hi-flow cat i'm looking at.
https://www.sau.com.au/forums/topic/223110-whats-this/
it could be an exhaust gas temp sensor.. just go to your local exhaust shop and get then to weld a new nut close to it's original location once you have fitted the new cat, or you could move it to the right of the flange in the photo if you want to do it before you fit it...
https://www.sau.com.au/forums/topic/223110-whats-this/#findComment-3930547
its a precat heater IIRC...but i can be wrong
your cat doesnt work efficiently until its hot
that aids it in heating
take it out of your cat, and push it up above into the hole the wire comes from. if you disconnect it a light will come on on your dash
https://www.sau.com.au/forums/topic/223110-whats-this/#findComment-3932509
no sorry definately not a preheater for the cat on these.
it is just a cat temp sensor, it runs a light on the dash if the cat gets too hot (ie blocked). I have been running with mine disconnected for years.
+1 when i got my car i used to hit bumps and see a red light flash,took it in and got a new cat sensor,then a lil while ago i was in my local spot with my bikes and had a bit of fun in a huge open area of dirt/grass,broke the bead on 3 of my 18's and snapped the cat sensor wire clean off...lights on constantly now.ya get used to it :thumbsup:
https://www.sau.com.au/forums/topic/223110-whats-this/#findComment-3942334
your lights not on?
on my cedric it got ripped off and the light came on
https://www.sau.com.au/forums/topic/223110-whats-this/#findComment-3942356
ahh oki doki this was on a 32gtr it doesn't show an error when you disconnect it. If it does, and you don't have a bung in the cat (or no cat at all like us) just chuck it under the car somewhere it can read ambient temp
https://www.sau.com.au/forums/topic/223110-whats-this/#findComment-3944713
Kind of off topic.. but why the hell do people put exhauste temp gauges in?
Who cares what exhaust temp is?.. its on its way out?
i know some people use the exhaust gas temp displayed on a gauge as a rough sign of what the afr's are doing, its an old school way though.
https://www.sau.com.au/forums/topic/223110-whats-this/#findComment-3947591
ahhhh ok
yeah on the stagea i just put it up inside the body through the hole it came out of
https://www.sau.com.au/forums/topic/223110-whats-this/#findComment-3955493
  • 1 year later...
old school thread revival YEW!
I put my new dump and cat in today and for the life of me I cant get the cat temp sensor out of the old cat (any ideas)! iv soaked it in WD40 and it wont budge so I think im gonna snip it off and plug the hole in the new cat with a bolt or something that should be sweet right? will it be ok if I cut it right up near the body?
thankyou for any help
https://www.sau.com.au/forums/topic/223110-whats-this/#findComment-5178705
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
