Posted this in a new thread since I can't edit the old one.
Ok Gave hume a call. I reckon probably the best time to Book is:
29th June Sunday or 6th July Sunday some time.
Cheapest way to do it is to book the whole track out for an hour. Cost is 540$ So if we get 10 people it's 54$ each
Maximum of 10 karts in one race. If we get more than 10 people wanting in, could probably work something out, but would probably need some like 16-20 people, and then we'd book it out for two hours.
Format would be : 3 x 15 minute races or 4 x 10 minutes races. (plenty to tire you out lol).
If people are in on this, please advise what days you can make it or not. If we get 8 or 10 will book this in. Booking the track exclusively for an hour is the cheapest, means only us are on it too. Hume also has a BBQ etc to use.
https://www.sau.com.au/forums/topic/223181-go-karting-dates/
  • Replies 60
Yes for 2 either date currently.
Can you check the format. 4 x 10min = 40 mins allowing for breaks we should be able to get 5x10min in I think.
Comparing to normal prices of $45 for 3 x 10 min and we don't need to have any specific numbers, which is the better deal?
You can try but trust me I think after the 4th race you'll be pretty knackered.
Checked the format on the phone. I think other wise, each 10min race is charged at 17$ so thats 68$ for 4 races compared to 54$ if we get 10 people. A 5 minute break between each race isn't too much anyway.
Can have a look of doing it individually, but it is around 17$ for a 10 min race, or a bit more for a 15 minute race.
I agree that after 3 or 4 races the arms are very tired. If you ask the guys how much 30 mins is (3*10 min races) you will find it is a LOT cheaper than the 10 min race by its self.
This way we don't need 10 people and we don't need a set time.
The price for 3*10 mins sessions is only like $40 but you can get caught up with slower people or real arseholes if you don't hire it out
Ok Unless I cant count looks like 7 people have said yes so far. Will give it a day or two before I decide to book in, looks like 29th of June.
Also just to cover myself, need to tell you guys you will need to sign a disclaimer form, just incase something happens as usual, you will also either need to bring a helmet or use one there.
Probably a bit too late to book in an hour now, this thing slipped my mind, bit short of 10 people too, but happy to turn up sunday arvo to have a go just booking in individiually, or reschedule to some other time.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
