been on this for about 4hours now, and i can say it is pretty f*kin hard lol...
dont blame me if your boss catches you playing instead of working...
http://www.addictinggames.com/theworldshardestgame.html
edit: 189 deaths aswell...
Edited by chris_r31
https://www.sau.com.au/forums/topic/223216-worlds-hardest-game/
so far cant even get passed the first level.....lol
Finshed.... have to say its the hardest game ive ever played....i just got paid to play this for nearly 2 days strait... :whistling: i love cubicals
pics of last level for you guys aswell.... do be confused.. it says that the level is inpossibile before you start... and looks it. its actually one of the easier.
cant belive i wasted 2 days of my life on this.... you bastard chris 31!!!
