i have a gtst r33, series 1 skyline. wondering the best route to go to turn up the boost on the stock snail. i was told the greddy profec requires an hks fuel cut eliminator....
is there a boost controller that takes care of raised fueling needs?
i feel like a total retard going from high comp NA hondas to boosted nissans.
thanks for the help.
How is the condition on your turbo? Stock or Aftermarket?
I think R33 have ceramic internals for their turbos, so don't go too hard.
If you got aftermarket turbo you can go a bit more boost.
Then you might need a front mount intercooler.
I don't have much experiance with boost controllers, but Im sure the big brands like APexi, Blitz and HKS will do a good job.
Ppl then might say you need a APexi Power FC to map out your air / fuel mixtures.
turbo should be ok, car has very low miles. im not looking to get ridiculous. i am getting a FMIC in a week, thats why i am asking, because i know with a front mount, i am going to get a pressure drop.
i guess stock is something like 4psi to 8psi dual stage(you guys use metrics?) and im lookin for i guess something like 12psi on the stock turbo with a front mount.
that should hold me over til i pick up a atermarket manifold, turbo and external wastegate.
just go get a maunual boost controller for ya local rev head store and you can safly wind her up to 11-12psi if you got a front mount really limits of the stock turbos rear wheel, there is a thred in diy on installation of a manual boost controller
If you get the correct size intercooler, boost lost should be a problem, I don't think..?
BTW ppl talk about removing the boost restricter in the hose going to the boost solenoid... There is talk about this on GTR's but have a look at the GTS-T.
The restricter is a little cylender inside the hose with a smaller diametre in resulting in a boost restriction. Squeeze the cylender out and plug the hose back in and you should get a Factory Safe Boost Increase.
I haven't found any solid evidance to prove this and best is to ask your mechanic.
Someone might wanna clear this up for me...
when i read you guy's posts, i read them wit han australian accent in my head. is that weird?
Mate! Get da farken boost up!
Stop beeina weak karnt!
LOL! :banana::banana:
Whatever helps you understand I guess... LOL!
Edited by (00)SKYLINE(00)
Probabally no weirder then the mental picture I get, of a slow stuttering Texan drawl, handgun in one hand, bible and 1st amendment flailing in the other... from reading post by Yanks :P lol
Edited by GeeTR
No boost restrictors in 33 gtst's that I know of.
They do run a dual-stage solenoid though. Have a look in the DIY section there should be an easy mod to make it run 7psi all the time instead of 5psi then 7psi. After you've done that get a Turbotech manual boost controller and wind it up to 12psi.
She'll be right mate.
Hey T.
Where are you from in the states.
Which liner do you have?
I'm from NYC but moved here from Vegas.
I have a gtst 96.
But I am an American...LOL
LOL! Your profile says your from Sydney...
this is the route im going, i ditched the little hose from the boost solenoid to the "t" fitting with the restrictor in it, by passed the coolant hose thru the throttlebody and tonight i am ditching the dual boost gimmick, looking for a manual boost controller and a boost gauge tonight as well. that should give me enough kick in the ass until i put a top mount, garret, FMIC.
Probabally no weirder then the mental picture I get, of a slow stuttering Texan drawl, handgun in one hand, bible and 1st amendment flailing in the other... from reading post by Yanks :) lol
thats 12% of the country, but hey, you guys have your "mick dundees" like everyone else too.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
