hey guys
im new to skyline ownership and these forums.. (just traded up from an old commonwhore.. best decision i ever made!)
ive noticed that with sensible driving im only getting about 330kms per tank, and there are quite a few black powdery flecks on the rear of the car, but nowhere else...
is it possible that a rich air/fuel ratio could be causing these two problems?
any help / advice much appreciated!
thanks
Ric
https://www.sau.com.au/forums/topic/223854-help-bad-fuel-economy/
Does it come with aftermarket ECU? My old 180sx does that, because the pfc tune was too rich.
My 32GTR, stock with just a exhaust makes 400km a tank, around 15L/100km. Thats with mixed highway and street driving.
Check/Change/Clean your air filter, fuel filter, O2 sensor, AFM and you should see economy improve slightly.
Edited by __PhaseShiftDown
hehe my line gets about 200 kms and thats with only a bit of boosting and its a stock 33s2 with only a catback and i know mine is running rich just to lazy to get a new 02 sensor because i know my AFM is good
actually thinking about it would be cheaper to put it in to a workshop to get replaced than to keep paying for more fuel
If you only just got the car and the place you bought it from haven't serviced it before they sold it to you. Defitnitly change the oil, oil filter, fuel filter, air filter. Clean the AFM using non-lubricating contact cleaner (buy from jaycar) and also replace your O2 sensor.
When I got my 32, it came with new air filter and oil and oil filter...etc. But they didn't change the fuel filter, after I replaced it, the car feels a lot more responsive and willing, the fuel economy improved a bit as well. So defitnitly replace the fuel filter as well.
hey guys
thanks
Ric
Because of this, i'm glad you saw the light.
snappy: lol i was never in denial about how pov my commodore was, i inherited it when my mum traded 'up' to another newer commodore, so i was just kinda stuck with it. i always knew that jap cars were much much better haha give me a little credit
ps. drove the commodore (trying to get rwc to sell it atm) the other day after a month in the 'line, damn thing felt like a bus!! lol
well well well... i told you to get a zed Ric...
Man I've got nissan datascan, shoot me a pm and we'll run your car on it and i can check out your o2's and everything else.... I finish up exams next week. I was gonna do a write up on fuel economy problems, but I'm not 100% familiar with skylines so I'll use your car a guinea pig.
We'll go cruising soon.
p.s. please tell me you bought a manual...
edit: just saw that you have an SII, not 100% sure if my laptop will plug into an S2 33, I know it plugs into SI. I'll find out anyway
he he when you can fix zeds you can fix anything Nissan ;)
well my laptop won't plug into your ecu, but you should still be able to do an ecu diagnostic using the flashing light on your ecu. there should be a tech article somewhere on here. otherwise you can test your o2 using a multimeter. you want your engine to be nice and warm, the voltage from the o2 sensor should be cycling 5-10 times every 10 seconds at 2000rpm when everything is at operating temp.
other things to check would be the coolant temp sender (should be on the top coolant pipe). Sometimes the connector gets corroded and it interferes with the temp signal. when this happens your ecu may think your car is always running cold and it will richen up the fuel mix. also if your thermostat is stuck open your car will run too cold and your fuel economy will be shit.
don't worry, i won't wreck your baby. I've pretty much had to redo most of the stuff on my car. when i got it i was getting about 200km/tank, had to fix up detonation sensor wiring, cleaned coolant temp sensor, replaced both o2's, fixed up all my vacuum leaks, replaced all the fuel lines, cleaned afm, cleaned throttle bodys, replaced blocked cats, new spark plugs, series 2 ptu, replaced air filter. I now get about 450km to a tank of normal driving and i can get 600km on the highway. Next week i'm pulling the plenum off and getting the injectors cleaned and flow tested and i'll replace all the o-rings and run new vacuum because that's all i have left to do.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
