thanks for that steve....looks good on the Dell 22"
Port Adelaide was exactly where I was thinking but trying to find an area with no or very little traffic could be an issue......unless its 4am.
Over a bridge to get that curved effect then photoshop the car out, leaving the stove trails, would be good but you don't want another car crossing while the shutter is still open.
love that shot :P
thanks i would upload the full res pic only its about 6mb......
as for the wheels they were nice till i lent out the car and it had a bang, so there off getting repaired now, god knows what theyll come back like :banana:
Edited by mick-skyline
you dont have to edit it in photoshop mate if the shutter is open long enough theyll just be a stripe :P
how do u get the light trail??
you just use a tripod and a long shutter speed if you look at this one closely
youll see that theres a white line on it where i was actually on the way back before the shutter closed.
wow that is trippy! how long till the shutter closes?
wat camera?
i want one! lol
im using a 400d
about 2mins it was open maybe 3
cool.....do you remember what shutter speed you used and what speed the car drove away approx.
shutter speed was 3"2.... drove away at drag launch after sitting for about 30seconds
mick what size n offsets are your cr kai's?
any side on pics that show the angle of the spokes?
wheels are 18" x 9.5 all round offset of 30 i think will have to double check the offset though... let me find a pic...
hmm, ok.....so was the shutter open during the 30 secs that you sat there cause I would've thought the car would be visible if that was the case
it was.... i was tryin to get the lights to be a bit brighter. car would only be still there if i stayed for more then half of the shutter or it was brighter out i think could be wrong though, dont really know why its not...
thanks for the info....always good to ask which saves us experimenting too much
best one so far, shame its an old pic lacking a lot of mods. but as strange as it sounds, to get a good pic of ur car, its not about the car. u need to consider background, theme, time of day, locations of the objects in the image, etc. quickly taking a snap in ur driveway after u washed it wont cut it :P
and i managed to take this on a shitty 2mp nokia.
btw its not a skyline :banana:
Edited by steveP
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
