Thanks Kellie, its the cover shot off HPI Magazine...hows the business coming along?
Cara, your car looks the goods!
hey bud, how about some pics of that engine bay......looks very nice from the little that I can see
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
