What did it pull on the dyno, Rhys?
that was from a classic ford magazine dyno day/ photoshoot managed that day i think around 85rwkw & 260NM (single overhead cam pinto w/ sierra fuel injection & a long list of mods), sounds laughable compaired to some RB figures but in a car that weighed 900kg with driver it was enough to beat most stock 32gtst, v8 commo/falcons :P
Rhys, love the GTR in that colour, nice work.
cheers :P
Edited by rhys5169
Thanks Kellie, its the cover shot off HPI Magazine...hows the business coming along?
Cara, your car looks the goods!
thanks love :P urs looks awesome too!
another of my favs , gotta love sponsors!!!!!!!!!!!!!!!!!!
thought it was..........
he has done a great job for sure!
wat ya mean??
no one bought it from me coz i totalled it beyond repair
that is why i miss it, i'd do anything to get that car back
wat ya mean??
well, dont drive like a fuuk-tard and you wont loose it :)
specially if your driving capabilities are minimal :P
